E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > [Help] AT problems after changing fluid
Reply
      06-10-2018, 12:24 PM   #1
Elias_E90
Elias_E90's Avatar
Lebanon
25
Drives: E90 328i
So a years ago (approximately), i changed my AT fluid at a shop, a while after my transmission started slipping. Replaced my torque converter with a used one and the car ran fine.
A week ago, the egs threw a code related to oil quality/oil level low, and the transmission wasn't running smoothly so i changed the fluid/filter/gasket like last time. Now the torque converter is slipping again. What should i do? I am guessing there is something these shops are doing wrong (maybe the oil level is low?) When refilling, he told me to start the car in neutral and he pumped oil till the AT was full.. the car was running smoother after the oil change..
Any help is appreciated. Tx
E90 328i n52 auto, 3 stage IM, k&n drop in, charcoal delete, silicone boot, ebay headers, secondary cats delete, bpc tune. MILVs (soon), MT swap (planning)
      06-10-2018, 01:09 PM   #2
Big Mexican Women
Drives: 2011 528i
what sort of fluid did you use? this is very unusual, I have never, ever heard of anything like this happening before. I would recommend reposting this in the general e90 section.
you should have changed the shift solenoids while you were in there. what is your mileage?
      06-10-2018, 02:04 PM   #3
Elias_E90
Elias_E90's Avatar
Lebanon
25
Drives: E90 328i
I am at 106k miles. Ill take it to another shop to check the oil level, i think it may cause it
      06-11-2018, 08:40 AM   #4
rothwem
Drives: 2009 BMW 328i Wagon
2009 BMW 328i  [0.00]
You're filling the fluid with the car running, right?
      06-11-2018, 09:36 AM   #5
Elias_E90
Elias_E90's Avatar
Lebanon
25
Drives: E90 328i
Yes, i took it to another shop today, he said that the torque converter has a problem but it is still in the very early stages. He said that i should try adding a bottle of torque converter fluid that treats the oil and the problem will be gone for a time
      06-12-2018, 02:29 AM   #6
Elias_E90
Elias_E90's Avatar
Lebanon
25
Drives: E90 328i
So i added the lube today, it is called lube gard instant shudder fixx. Ill try the car and report back to the thread
      06-12-2018, 09:50 AM   #7
nsjames
Drives: 08 328xi Touring
lube guard products are legit.
but if you're getting TC shudder I'd look at the lockup solenoid or the pressure controll stuff.
https://www.sonnax.com/parts/4629-re...red-valve-body
      06-15-2018, 10:51 AM   #8
Elias_E90
Elias_E90's Avatar
Lebanon
25
Drives: E90 328i
Id say 90 95% shudder is gone
      06-15-2018, 02:03 PM   #9
tlow98
Drives: 2009 E91, 2014 F15 x35i
Interesting. Thanks for reporting back
Reply
e90post
