06-12-2018, 07:37 AM | #1 |
Rep 35
Dinan Sport install issue
I'm having a problem removing the sensor off the charge pipe and don't want to break the sensor by forcing it. I used contact cleaner to help loosen it, but it still won't come off, any suggestions?
Thanks in advance. |
06-12-2018, 10:23 AM | #2 |
Rep 1,499
you don't need to remove the sensor from the charge pipe. You just unplug the connector from the sensor and plug one end of the Sport+ into the sensor and the other end into the connector.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids |
06-12-2018, 10:44 AM | #3 |
Rep 35
06-12-2018, 12:00 PM | #4 |
Rep 1,499
Sometimes the snap lock can be difficult to unlock. Use a small flat head screwdriver to pry the snap lock up while you pull on the connector.
06-16-2018, 09:59 AM | #5 |
Rep 35
Thanks, that worked! I used a small flathead which lifted the lock and then pushed it out with the screw driver, took a hot second. That pipe hovering over the charge pipe is annoying.
