hard to shift into first gear?
03-18-2006, 07:11 PM | #1 |
Rep 171
I've got around 1000 miles on my 06 330i. Since I picked it up, the shifter has been a little tough getting in first gear. If I blip the throttle to 1500rpms, it goes in easier. This is at a complete stop, btw.
Does anyone else's shifter resist going into 1st, without at least a little coersion? |
03-18-2006, 09:49 PM | #3 |
Commander in Chief
37
Rep 1,034
I have been having similar problems. What makes it even more unusual is that it seems to be getting worse as the weather gets warmer.
I, too, find that blipping the throttle improves the situation. When I get the time I will have to get this checked out. If you get any further information about this problem be sure to post it.
2008 BMW 535i Space Gray, Black Leather, Dark Bamboo Trim| Sport Automatic with Paddles | Sport Package
2008 BMW M5 (gone, but not forgotten) Space Gray, Silverstone Merino Leather, Madeira Walnut Wood Trim | 7speed SMG | All options Mods: Corsa Exhaust | RPI Ram Air Intake | H&R Sport Springs | Rogue Engineering 12mm spacers |
03-18-2006, 10:21 PM | #5 |
Rep 1,024
I dunno about the E90 but in my last 2 cars there was no synchro for first gear so you always had to rev match to get into first unless you were stopped or going very slow. Try double clutching and see if it works better.
330i Monaco Blue, Terra /w aluminum trim, SP, PP, CA, PDC, Nav, Folding Seats, Sat Prep European Delivery Blog Picture Gallery |
03-19-2006, 07:15 PM | #6 |
Commander in Chief
37
Rep 1,034
Maybe I should clarify my post. I was referring to having difficulty shifting into first at a complete stop. Usually while at a light, I leave the car in neutral with the brake depressed. When the light changes, I pess the clutch and shift into first before driving off.
There have been several instances where the situation goes like this (keep in mind this is at a complete stop): -press in the clutch -try to move the shifter to first, but it won't engage. -try again to move shifter to first, still won't engage -try once again to shift to first (by this point, the car behind me begins to blow thier horn), still won't engage -blip the throttle, and shifter finally moves to first -drive off I have about 9k miles on my car, so by now it should be well out of any break-in period. I don't run into this problem every time I come to a stop, but it has happened several times since I purchased this car in August 2005.
03-19-2006, 07:18 PM | #7 | |
Rep 4,838
03-19-2006, 08:12 PM | #8 |
Rep 3,011
It's strange that this is getting worse with warmer weather. Tranny fluid/oil needs time to warm up, so it should get batter as you drive. I've had trouble getting into 4th gear at times... frm 3rd or from 5th. Usually in teh mornings when the car is cold.
"Teach the ignorant. Ignore the stupid."
03-20-2006, 07:40 PM | #9 | |
Rep 244
Get a CDV mod...that should fix your problem. |
03-20-2006, 09:59 PM | #10 |
Black Sapphire 330i
32
Rep 362
Sometimes wen my car is cold, 1st gear is harder to engage. With the clutch in, I shift into 2nd, and then up to 1st. Seems to get it in there. If there's no synchomesh for 1st, the double clutch idea is best.
03-21-2006, 10:30 AM | #12 | |
Rep 230
Re: 1st gear I had several cars that do that. It gets slightly better with time. I bet it's a synchro idiosyncracy ( ). Try letting off the clutch once, and try again. It can be annoying, but it's not broken.
Compos Mentis
----------------- 2006 330xi Arctic, black leather, aluminum. 18000 miles... |
03-21-2006, 11:02 AM | #13 |
Rep 3,924
agree, CDV will definitely NOT solve this problem. you should have that checked out. i find a little resistance in going to 1st but it's merely even noticeable anymore.
2011 E92 M3 - IB/Beige/Sycamore Wood/6MT/EDC/ZPP2/Nav/PDC/Heated Seats/iPod-USB/Enh. Audio
2008 E92 335i - Montego Blue/Black/Gray Poplar/6MT/ZPP/ZSP/Nav/PDC/Heated Seats/HDRadio/iPod-USB - Sold 2006 E90 330i - Mystic Blue/Black/Aluminum/6MT/ZPP/iDrive/PDC/Heated Seats/Sat. Prep - Sold 1994 E36 325i - Boston Green/Beige/Automatic/ZPP/Heated Seats/Premium Sound - Sold |
04-06-2006, 12:45 PM | #14 |
Rep 17
Actually, I am having the same issue. It happens about once or twice per trip. By car only has 300 miles though.
Hopefully it will get better after some more break-in miles. By the way, I came from a Honda and the clutch/shifter were way smoother than my new e90. |
04-06-2006, 02:40 PM | #15 | |
Rep 86
When it hesitates to go to 1st gear from a complete stop, I shift to 2nd gear to line up the gears, then it goes smoothly into 1st. Hope this helps. Niko
|U.S. Spec. 325i | 6 Spd. Manual | Titanium Silver | Black Leatherette | Aluminum Trim | Sports Package | Xenons | Sat. Prep. | |
04-07-2006, 08:52 PM | #16 |
Rep 1,190
Drives: 335i AW Sport 6MT
You have to double clutch going into first. Got to rev match and it will go in smooth.
12-07-2006, 10:21 AM | #17 |
Rep 16
I've had this problem too. I put the car in reverse and pop it back out and it'll go into first smoothly again.
2006 325i Jet Black/Terra/6spd/Sport/Xenons
1991 VW GTi 16V Red/Factory Recaros 1992 VW Corrado SLC |
12-07-2006, 10:41 AM | #18 | |
Commander in Chief
37
Rep 1,034
Problem solved. Now that I have a new transmission, the shift to 2nd is also improved. I never had a problem with jerky shifts to 2nd, but at high RPM's I used get a very slight grinding sensation. That was also eliminated.
12-07-2006, 11:05 AM | #19 | |
Rep 6,563
Someone said reverse. I would rather not do that since 1) reverse require some muscle and 2) if car behind you see the reverse light, they might beep you.
under construction! |
12-07-2006, 12:42 PM | #20 |
Rep 1,138
normal, happened on all my past manuals. Just let the car roll a little, and work the gears up and down before going back into 1st, and it should work. Just dont overforce it in.
12-07-2006, 03:10 PM | #21 |
Rep 2,221
HAHA i had the same problem. all i do is pump the clutch and then the 1st gear engage's
