10-03-2018, 12:19 PM | #1 |
Rep 3,047
Drives: 2019 M2 Competition
F80 M3 controls arms install questions
Hey yall:
I am definitely considering this, well correction, considering this depending on cost as my budget as always is super constrainted. F80 What do you guys think of this? Anyone done the same? Outstanding questions I have at this point. 1. arm part numbers right - 31122284530 - $208 left - 31122284529 $208 2. headlight control rod part number - Whole kit including arms and control rod - $386 https://www.ecstuning.com/b-genuine-...31122284529kt/ 3. proper torque - ??? Worth it?
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread Last edited by BMW DIY Guy; 10-03-2018 at 12:33 PM.. |
10-04-2018, 11:11 AM | #3 |
Fool
1857
Rep 3,542
It should be noted that you also really need the tension struts as well as the control arms. With just the control arms the wheel moves a long way forward in the arch as you can see in the video. F80 tension struts fix that.
10-04-2018, 11:04 PM | #4 |
Rep 3,047
I appreciate the info.. interesting those are needed too? Wonder if there is real benefit from doing this?
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
10-05-2018, 01:07 PM | #5 | |
Rep 1,827
I'm a fan of bkkeys so seeing this sucks. Gotta be honest though, I did chuckle at the vid a little bit, in a sympathetic, nervous laugh kinda way. He seems in fairly good spirits and definitely toftt! https://www.youtube.com/watch?v=iL_Xgl-Hb-s
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
10-05-2018, 01:26 PM | #6 |
Rep 928
I'm doing this def worth it better bushings and more neg camber
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
10-05-2018, 02:01 PM | #7 |
Rep 5,460
Drives: F30
Ive also been looking into this.
Anyone completed this DIY ? |
10-05-2018, 03:04 PM | #8 |
Sedan Driver
389
Rep 1,018
Was going to do it for my car a while ago but realized it wouldn't work on xDrive. I'd do it.
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug |
10-05-2018, 03:19 PM | #9 | |
Rep 891
It turns out he himself had an xDrive car and attempted this. Now we all know exactly why you cannot do this on an xDrive car. I watched the video in the top post before and assumed he had RWD, guess not. For those with sDrive, this mod was very worth it. They improve all elements of steering and give much more grip on the front end through all corner phases. I did not do tension struts. The TS do not correct the wheel placement in the well (I later swapped to F80 TS and they mildly corrected placement, pushing the wheel further back and outward), the F80 TS are the same length as the F30 ones. The forward placement is not a problem clearance wise even with my car lowered and running wider tires/wheels. The F80 TS would be worth it for the bushings, but are not required.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 05-15-2019 at 02:48 PM.. |
anotheran389.00 |
10-05-2018, 04:09 PM | #10 | |
Sedan Driver
389
Rep 1,018
X BMW F8x lower control arms (spacers needed?) $169, 169, 169, 169 (31122284529, 31122284530, 31122284531, 31122284532) - won't fit xdrive suspension
10-05-2018, 05:14 PM | #11 | ||
Rep 5,460
Drives: F30
10-05-2018, 07:17 PM | #12 | |
Rep 10,473
As this adds negative camber, won’t the alignment shop attempt to correct that when aligning to factory specs? Depends on the distance to alignment shop. Last edited by IK6SPEED; 10-05-2018 at 07:48 PM.. |
10-05-2018, 08:31 PM | #13 |
Rep 3,047
The video has a solid walkthrough of the arms themselves, and the link to the kit has the arms AND the headlight arm you will need.
10-05-2018, 08:37 PM | #14 | |
Rep 3,047
OMFG I can only imagine the horror on this.. So still (sorta) thinking about this NON X DRIVE.. but what are the other parts folks mention? Last thing I want, or can afford to do, is break things trying for a little better handling.
10-05-2018, 09:54 PM | #15 | ||
Rep 891
Here is my coilovers only alignment: And here is my post install and post alignment specs:
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 10-05-2018 at 10:00 PM.. |
10-07-2018, 01:44 PM | #16 |
Rep 3,047
huh.. this has that biting off more than I can chew right now feeling. Still need to change suspension, look at big brakes.. so on and so on.
10-09-2018, 03:00 PM | #17 | |
Rep 10,473
The F30 felt unstable with crosswinds on a highway to where he felt unsafe driving it. |
10-09-2018, 03:21 PM | #18 | |
Rep 5,460
Drives: F30
Do you know what other suspension setup he had? Appreciate the insight as this is/was on my to do list to compliment my B8 / ACS set up. |
10-09-2018, 03:28 PM | #19 |
Rep 10,473
10-10-2018, 09:21 AM | #22 | |
Rep 891
Highway stability and tracking improved after the upgrade. I did a 1000 mile road trip a few months after having them installed and the increased caster improves centering force which keeps it tracking more true with less input. Take a look at the threads on 2addicts on the topic, there are tons more people there who do this mod. The F22 and F30 share the exact same suspension architecture and geometry. Here's one of many, but a search for "F80 LCA" will get a lot of hits. https://www.2addicts.com/forums/show...1079766&page=7
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
sspade2475.50 |
