E93 window problem
10-06-2018, 09:53 AM | #1 |
Rep 1,462
E93 window problem
The front passanger side window on my 08 e93 has a weird problem. The if i roll the windows up using the button that controls all 4 windows at the same time or while putting the top up, that window tends to roll back down on its own once its rolled all the way up. Any ideas?
10-08-2018, 07:29 AM | #3 |
Rep 5,458
Mine has done this for the better part of the last 5 years, not all the time, maybe once in 5 or so times, I have tried the window limit reset procedures and it doesn't seem to help, so I have just lived with it so far, but it is always and only the passenger front window that has the issue. I am guessing it is just a little tight and sometimes invokes the pinch sensor - maybe a minute adjustment to not have the window go up 1mm less would do it but assuming that means taking off the door panel and maybe adjusting the glass on the regulator.
2025 X5 Msport
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
10-08-2018, 08:24 AM | #4 |
Rep 1,462
Yeah mine dosent do it every time, but recently it seems to be doing it more often. But I guess its not too huge of a problem, trying to fix it seems like more of a PITA than just living with it.
10-08-2018, 10:19 AM | #5 |
Rep 5,458
Here is a good thread that is 10 years of issues and no solid resolution some say software fixes more say new motor fixed and a there is one more recent about regulator adjustment might try that my thinking is the top has a little variation when closed just enough if the window is tight to trip the pinch sensor and adjusting it just a little bit lower in the regulator may fix who knows!
https://www.1addicts.com/forums/showthread.php?t=278352 |
