Body Shop Failed At Installing My Rocker Panel/Side Skirt.., Need advice
10-12-2018, 05:11 PM | #1 |
Rep 602
I ordered m3 style rocker panels from ECS tuning and the body shop installed them like absolute shit. There is a gap in the center line and they don't sit flush. As I am driving the gap is opening more and more.
They failed to install them to the car before painting. They went straight to painting and put them on with clips. I have gone a second time and they re took them out and now it looks even worst when they put new clips in! Any advice in this recommendation? I told them if they can glue it on and they said there is no space to glue or make it work
Vermillion Red
10-12-2018, 05:21 PM | #2 |
Rep 709
No expert here, but if you can put back the original panels, would they go back perfectly?
It could be the one you got is not that great of quality?! Maybe measure the distances between the clips of the original and the new ones. |
10-12-2018, 07:04 PM | #4 | |
Rep 602
I told the body shop if they can heat up the plastic and make it fit flush. They seemed lazy and careless. The rockers use OEM clips but stick out a lot more. What work would they need to do to make them fit?
Vermillion Red
10-12-2018, 08:00 PM | #5 |
Rep 2,494
I have the same rockers. They don't fit perfect even with work (too short front to back). For lack of a better term, the "slots" for the clips on the M3 rockers aren't in the right spot either, which makes getting the rockers to completely lock on to the clips nearly impossible.
If you pull off the rockers, you'll see that for each spot where a clip goes, there are 2 small tabs that the clips should sit between. What I did is cut all those tabs off with a box cutter. This allowed me to fully seat the clips onto the rocker panels so that they are at least flush with the doors and don't have a huge gap. Photo attached. The horizontal rail is what the clips latch onto. See the little nubs on it? Remove those. EDIT: also, either reuse your factory clips or get a new set of OEM clips. The ones that come with the rockers are junk.[IMG][/IMG]
MTK24484.50 |
10-12-2018, 11:20 PM | #6 |
Rep 602
thanks fravel. I will show your message to the next body shop I go to.
I was told that clips can not be re used once they are taken off?
Vermillion Red
10-13-2018, 02:12 AM | #7 |
Rep 104
Was the "body shop" named MAACO ??? A REAL body shop does Fab work and can make any panel fit issues work and look 100 % I suggest you give them a nice fucking review and plaster their name all over. If they give a shit about making money and gaining new customers they might tell you to bring it back.
10-13-2018, 02:14 AM | #8 | |
Rep 602
A few blocks away from BMW Seattle actually. I don't want to put no names and leave them on blast. My car was side swiped and they replaced my door and rocker panel. I wanted the m3 style and had them paint that and install that on. Their excuse is "it's not OEM, not our problem"
Vermillion Red
10-13-2018, 03:50 AM | #9 |
Rep 145
After market panels are shit no matter who makes them, they never fit properly and the time and effort to make them do so you wouldn't want to pay for. it would be less costly to buy genuine ones in the long run. coming from a body man of 40yrs experience.
10-16-2018, 03:11 PM | #10 |
Rep 602
I ordered new spacers and pins 20 each side, 40 total.
It costed $75 from the dealer. Well here goes a third time install
Vermillion Red
10-16-2018, 03:22 PM | #11 |
Rep 1,484
my buddy that works at body shop said the same thing when he installed the m3 skirts on a e92. He said you had to tweak it to make it to fit and they dont bolt on like oem from the factory.
With that being said, he said any decent shop should be able to make it work. Maybe try more of a custom body shop that has more experience working with aftermarket parts. I'm sure the BMW cert shop is probably used more for accident repair where they just order BMW parts, paint it and install. |
10-16-2018, 03:38 PM | #12 | |
Run Deep
15129
Rep 4,123
Drives: Back and Forth To Work
Garage List 2018 Alfa Romeo Giu ... [0.00]
2022 Ford Bronco 2d ... [0.00] 2016 Alfa Romeo 4C [8.50] 2019 BMW i8 Roadster [10.00] |
^This. Most BMW Certified body shops are not in the business nor have the inclination to do any type of fabrication work. This isn't justifiable to them from a financial standpoint. This would be better accomplished at a custom fabrication shop. Also, I believe that it is best they paint the part whilst off the car - better outcome that way, so they likely did that part correctly.
Don't sweat petty things....or pet sweaty things.
