328 wont start...e90 help
10-14-2018, 02:40 PM | #1 |
Rep 58
My e90 328 07
The car will not start.. No click , no sound, the brake pedal is hard... Insert key, it shows red airbag, red brake light , then a yellow explanation symbol on dash. I never had a start problem. 3 days ago someone hit my from rear end, car did start after that. Then I install new radiator and bleed the system .. After that car wouldn't start.. At first i thought battery was dead, battery fully charged and new. So far: checked fuses in junction box, Replaced b+ battery cable Please please help..... Why us the brake pedal hard and I'm getting explanation sign on dash? All power radios light. Locks are working. |
10-14-2018, 05:32 PM | #3 |
Rep 58
Yes,
I charged the battery through the front battery terminals... The car has complete power . I dont think its starter cause its feels like no power is going there to start it....especially if I cant press the brake pedal down. |
10-15-2018, 12:16 PM | #7 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
My starter went at ~95,000 miles, check codes and see if that's the issue. No other lights or noises when you press to start the engine? Full electric power throughout the car besides the engine not starting? Have you checked for any leaks or fluid levels?
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
10-15-2018, 12:19 PM | #8 | |
945
Rep 1,507
Someone else just had their starter go out on here and he said that he tried to start it 40 times in a row and eventually it fired up... I'm going to wager it is your starter though. How many miles on your car?
10-15-2018, 12:35 PM | #9 | |
Rep 4,330
there's the primary battery cable, should have 12V. starter solenoid will get 12V when the car commands the starter to engage. If you have voltage and the starter doens't work, starter is bad. if yo uhave no voltage, it's a battery cabling issue. |
10-15-2018, 04:08 PM | #10 |
Rep 58
I followed the video..
I think the Cas system wouldn't put out that code if the starter initiated.. That engine start failure code. Starter comes tomorrow, I'm still looking to see if it's anything else. I never got a click noise or ever had a starter issue.. This randomly happened immediately after I changed the radiator and bled the system. |
10-15-2018, 05:57 PM | #11 | |
945
Rep 1,507
______________________________ Did it ever run at all since the new radiator and coolant flush? Did you put anything in the radiator besides water/coolant, like one of those cleaning products? Maybe you knicked something in the process. Vacuum line perhaps, or maybe some wires? There is also an off-chance that you might have shorted something with overspill, maybe the starter. Double-check that there are no loose wires or hoses anywhere. After thinking about this issue for a while I would bet that you accidentally moved or changed something because unless your car overheats, coolant/cooling system is probably not to blame. Good luck, and I await an update in anticipation! Very curious as to what this could be.
10-15-2018, 06:26 PM | #12 |
Rep 58
replacing the radiator is just unplugging the fan, moving air box, i did disconnect mass air flow sensor.
I wouldve gotten that code, ive seen it before. I check the voltage to the upfront battery terminal 12v .. check voltage on battery terminal fuse box all power is 12v only thing that noyone has cleared up for me.. in the STARTER video when he tests the white starter 14g wire it looks like the harness is unplugged.. when I put the multimeter to that wire like he did I get 0.00v.. I get 0.00v plugged into harness or unplugged. I did find that same starter wire on the starter but i must move stuff to properly reach it. If a cable got disconnect would the passenger side front battery terminal still receive 12v? Tomorrow I will remove intake and see. |
10-15-2018, 06:28 PM | #13 |
Rep 58
either way im replacing the starter becuase it seems they just want to die after a few years of service..........
mines may have died at home in my driveway thank god |
10-15-2018, 06:29 PM | #14 |
Rep 58
And no ,
After the radiator installment and bled, it has not turned over. And inpa did detect emgine start error. Last edited by redblackbmw; 10-15-2018 at 08:28 PM.. |
