why can't i find any e90's with oil coolers?
10-14-2018, 10:06 PM | #1 |
Rep 541
I"m looking for a second e90/e92 .. i have an 07 coupe thats RWD with 118k and i'm looking to get something AWD.
So far i have not seen one sedan that has an oil cooler on it. I'm looking at the engine bay photos. Some have sport seats and paddle shifters but still no oil cooler in the engine bay ... how do i find a model with that? also a note, i read that if you were to 'retro fit' an oil cooler you'd need to upgrade the oil bump .. which that would be something i probably wouldn't want to do. |
10-14-2018, 11:09 PM | #2 |
Rep 2,476
Thought all "Sport", or is it "M Sport", optioned E9x models had oil coolers.
I don't think the paddles mean anything, other than AT. I also believe sport seats were an option without either of the above mentioned packages. |
10-15-2018, 03:42 AM | #3 |
Rep 2,738
I only see one part number for n54 oil pumps:
11417560250 But for n55 oil pump there looks to be 2 part numbers and I have no idea the differences: 11417613549 11417573747 This is just what I found in a quick search and I’m in no way 100% certain there aren’t 2 different n54 pumps but I didn’t see a second part number for one in a quick search I just did. Where did you read you need to upgrade the oil pump for adding a cooler? On other platforms guys add coolers and do nothing with the pump. Also our oil pumps are supposed to have variable outputs controlled by how the ecu perceived demand. I wonder if ECU would sense a lower pressure from an added cooler and increase output accordingly. I know a few guys local to me who have added a second oil cooler to N54 cars that came with a single factory one. When I asked they said they saw no low pressure issues. |
10-15-2018, 05:56 AM | #4 |
Rep 922
For the early years, you need the Sport Option PLUS the 18" wheel package to get the secondary oil cooler.
I have a 2008 XI with Sport package but with the 17" wheels. No second oil cooler. Look for a car with Sport + 18" wheel package. Should have the second cooler. You definitely can retrofit a second cooler. There are a few DIY's out there and there are some decent kits online for purchase. |
10-15-2018, 07:26 AM | #6 | |
Rep 541
Do you regret not having it? |
10-15-2018, 07:27 AM | #7 | |
Rep 541
10-15-2018, 07:33 AM | #8 |
Rep 506
I have an oil cooler on my N54 that came stock. but I also have the M-sport which had the 18inch wheels and it's a sedan.
2010 335I Xdrive
You're not really driving if you don't have 3 pedals. |
10-15-2018, 07:38 AM | #9 |
Rep 2,476
10-15-2018, 07:52 AM | #10 |
Rep 541
10-15-2018, 08:12 AM | #12 |
Rep 460
Our 2007 E92 with the sport 18" wheels did not come with the oil cooler. Build date was 3/2007. I'm told BMW started putting them with the April 2007 production built cars.
I went ahead and "retrofitted" the oil cooler myself. Makes about 20-30 degrees temp difference in the oil. |
10-15-2018, 08:14 AM | #13 | |
Rep 541
sport package, premium package, etc ... the more i hear the weirder this gets |
10-15-2018, 10:19 AM | #14 | |
Rep 564
I was waiting for one of you early 07 guys to chime in saying they have an oil cooler. Every thread like this has people going back and forth on when the oil cooler came standard. General consensus is the 07's didn't come with it but there's always someone who says they do. Do you have the sticker? Maybe it was an additional option at the time? Or maybe it was retrofitted? |
10-15-2018, 10:22 AM | #15 |
Clean is the new cool, keep it that way.
808
Rep 1,685
It is a " S823A-Hot-climate version" option thing, it has nothing to do with year or sport package, etc. Plenty of non sports came with an oil cooler.
For example, an 09' without it. https://www.autotrader.com/cars-for-...ckType=listing If I keep searching I am certain I will find a 09+ with the M sport package and no oil cooler. It just depends where you live, here in south Texas it would be harder to find one without the oil cooler.
2011 335i, FBO, N55+ Turbo, full E85, S55 intercooler, etc.
2015 X5 35i Xdrive Last edited by 9krpmrx8; 10-15-2018 at 10:41 AM.. |
6ixSpd6034.50 |
10-15-2018, 10:28 AM | #16 |
Rep 2,476
10-15-2018, 10:39 AM | #17 | |
808
Rep 1,685
Auxiliary radiator.
2015 X5 35i Xdrive |
10-15-2018, 10:46 AM | #18 |
808
Rep 1,685
Oh and random but this car has the full BMW Performance Bumper, sides, and rear.
2015 X5 35i Xdrive Last edited by 9krpmrx8; 10-15-2018 at 11:01 AM.. |
10-15-2018, 10:52 AM | #19 | |
Rep 2,738
This is done by guys local to me who are running 600+whp N54’s at strip and track and want extra cooling. The only reason I mentioned it was in regards to the statement about needing a higher output oil pump to run a cooler. They added a second cooler and said no issues with oil pressures. So I suspect you can add a cooler to a car without one and not have oil pressure issues. |
10-15-2018, 10:58 AM | #20 | |
Rep 2,476
Someone mentioned the Hot Climate package is needed to get the oil cooler. Might want to run the VINs through a decoder as you shop. |
10-15-2018, 11:01 AM | #21 | |
808
Rep 1,685
Well not necessarily, I look at the seats as a sure way to tell. I have seen the Sports multi function steering wheel on non sport packaged equipped cars.
10-15-2018, 11:11 AM | #22 |
Rep 2,476
Pretty sure that's an owner swap on the steering wheels, a common mod. Also not 100% sure, but I believe sport seats were available as an option on their own, without a sport package.
