Steering
10-15-2018, 04:34 PM | #1 |
Rep 21
Steering
Hi guys, i know this might be a weird one.
So a couple days ago i got my tires changed, from summer to winter tires, and as soon as i drive my car, i notice the steering is super soft, (turns smoothly and softly) and i know BMW's have harder steerings, which is better for control IMO. My car was the same before the tire change, i want the stiff steering back! Or is it just me and i feel the steering is lighter? thanks for your responses guys! |
10-16-2018, 04:26 PM | #3 |
Rep 21
I don't think neither are run flats, and no, the ratios and widths are the same.
Thanks! The steering just feels way way lighter than before and its noticable now. i dont feel the same when i drive it now, its turning too easily and smoothly |
10-16-2018, 06:44 PM | #5 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
So you're saying that it did or didn't change when you put the winter tires on?
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
10-16-2018, 07:31 PM | #7 |
Rep 2,738
They probably overinflated your tires or you had the old ones under inflated. Check the tire pressures my money is on them being overinflated.
10-17-2018, 08:49 AM | #8 |
Rep 18,808
You put winter tires on the car. The tread compound is different, thus a different steering response. The tire construction is also different. As previously stated, make sure the pressures are to spec. Some tire shops leave the pressure high (for initial bead setting) and don't drop the pressure before returning the car to the customer. Also, consult the owners manual, tire pressures for winter tires is usually different than for summer tires.
10-19-2018, 04:49 PM | #9 | |
Rep 21
