Car Won't Hold Idle
10-16-2018, 09:06 PM | #1 |
Rep 654
Car Won't Hold Idle
E90/328i/130k miles
First, the car won't crank at all. Battery was replaced - Link BT Tool - Reset Battery Adaptation Still won't crank! Replaced the Starter motor - Link Installation went fine Car started snappily. Engine started shaking and the idle could not be maintained. After few tries, engine just dies off after few seconds of trying to maintain idle Got following codes: Gearbox Control Unit Code:
CF17: Error will not cause a warning light Error is currently present CF1C: Error will cause a warning light Error is not currently present Code:
Car Access System 3 A0B4: Fault engine start starter Error will not cause a warning light Error is not currently present Code:
Instrument cluster PL2 A559: Clamp 30g_f cut off Error will not cause a warning light Error is not currently present UPDATE
So is the MAF gone? Or this could be due to a another breather hose lose from the starter motor installation? Last edited by sle39lvr; 10-16-2018 at 10:03 PM.. |
10-17-2018, 07:01 AM | #2 |
Rep 952
It sounds like you probably have a vacuum leak from a disconnected or broken hose. I would start looking for that first because it is the lowest cost, easiest item to fix.
bone stock
10-18-2018, 08:51 AM | #3 |
Rep 654
So I started taking apart everything for intake manifold. I found out that the hose that plugs in to the side of the throttle body has been pulled off.
Everything is fine now Thank you for the reply. Made me not order new MAF sensor, which wasn't the cause. |
