10-19-2018, 10:04 AM | #1 |
Rep 4,552
Drives: 2015 328d xDrive
Steering wheel heat not working after conversion
Hey all,
I did an M Sport steering wheel conversion on my non m sport 2015 328d and everything works except the heat. My car just has cruise control and heated wheel as options. On real oem is says the correct part number for the heating module is 61317849393 http://www.realoem.com/bmw/enUS/show...diagId=61_5666 The car is giving me an error message though and the heat does not work: Does anyone know what I can do to get it working? Is there coding required? Any help would be greatly appreciated. Thanks. |
10-20-2018, 02:17 PM | #2 |
Rep 3,039
Are you sure the steering wheel you got has the heated function? The wheel itself will have an element inside.
It's otherwise plug and play and should work. No coding required when your swapping a wheel that was already heated.
2016 BMW F80 ZCP
Instagram : 7IM3LESS https://instagram.com/7im3less?igshid=YmMyMTA2M2Y= |
10-20-2018, 02:18 PM | #3 | |
Rep 4,552
I'm leaning towards a broken/malfunctioning control unit or a loose/damaged wire somewhere
10-24-2018, 01:26 PM | #4 |
Rep 26
Did you get the correct wiring harness which has the connector for the heating? Or were you able to use the old?
In my car the connector for the heating had a blue wire in the harness. |
10-24-2018, 01:48 PM | #5 |
Rep 4,552
Old one came with it and it didn't work. Replaced it with another to make sure and same thing.
10-24-2018, 11:59 PM | #6 |
Rep 1,953
Drives: 2013 328i xDrive
+1. I have done a retrofit as well and I did zero coding for it. If you have another harness that you know works, you can try it out and see if that's the issue. If it's not, only other thing would be the heating element itself.
10-30-2018, 09:39 AM | #7 |
Rep 4,552
Update: Issue solved! The problem was coding.
10-31-2018, 08:55 PM | #8 |
Rep 130
Drives: 2016 bmw 328i xdrive
10-31-2018, 09:29 PM | #9 |
Rep 4,552
I wasn't present at the time so I'm not 100% sure.
