Rear Bump stop Confusion.. need help!
10-22-2018, 11:33 AM | #1 |
Rep 47
Lowering my e90 328xi this week with eibach pro-kit from europe and koni yellow
I am confused on which is the correct rear bump stop to use... There are many posts referencing Z4M 33507836826 (first smaller pic) I bought these and they measure 82mm in height... Then reading along I see this one Z4 33536770350 it measures from the picture 65mm in height. (second larger pic) So which one do I use? |
10-22-2018, 11:38 AM | #2 | |
Rep 156
N52 | +1mm MILVs | Catless | 3-Stage IM | BPC Tune | 3.64 diff | AirLift Performance 3H | M3 Control Arms | SPL Parts BumpSteer Correction | UUC Evo 3 Shifter | CCV Delete | Valeo SMF Flywheel | CSF Aluminum Rad | VAC Front Hub Extenders | BMS Cowl Filter Delete
10-22-2018, 01:06 PM | #4 | |
Rep 156
I think the lower you go the shorter the bump stop you'd typically want. Someone can correct me if I'm wrong. If you get a spring that doesn't lower very much, then try the longer one. Rear bump stops are easy to replace relative to fronts, so you might need to resort to trial and error.
10-22-2018, 02:20 PM | #5 |
Rep 47
The eibach kit will lower the rear from stock 20mm.
Does anyone know the height of the e90 stock rear bump stop for a sedan (not sport)? According to Real OEM the number for the stock part is 33536767334 Last edited by RiderOTStorm; 10-22-2018 at 02:25 PM.. |
