E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > 330d oil warning and detailing
Reply
      07-07-2008, 09:28 AM   #1
simonbenn
Drives: E90 M Sport Auto
Hi folks,
My 330d ('55) has started to flash an oil warning every so often in the last week. I've checked the level after a 20 min drive and and it's low, but I had an oil change in Sept. Would you regard this as unusual for a car that does city commute 20 miles a day?
So given that I'm disappearing off to France in the next few weeks I need to get this sorted. BMW want £230 for an oil service! So I'm tempted to get this done cheaper. Should I just suck it up and be done with it?
I'm up to 50K - any truth to the stories that oil starts to get consumed faster / starts to leak from the 3.0 diesels about now? at least that's what my searches suggest.
1. Can someone please look in their manual? - I don't have one to hand at work and tell me the oil grade recommended. (330d auto)
2. Where do I buy this magic elixir in a hurry? retail outlet please.
I think it's this but I'm not sure: http://www.e90post.com/forums/showpo...9&postcount=10
Appreciate any help on this.
Regards
Simon
As an aside I'm also after a detailer who visits in the Harrow area. Any personal recomendations? Thx.
      07-07-2008, 10:26 AM   #2
Jude1
Jude1's Avatar
United Kingdom
29
Drives: 3 Series
You'll need an LL-04 approved oil such as Castrol Edge 0w-30 or similar, if you need it today then try your local Halfords as the stock this. Failing this try Opie Oils and they'll have a few options for you and can normally send it for next day delivery. Worst case nip to your friendly BMW Dealer.
      07-08-2008, 02:27 AM   #3
PhilR
PhilR's Avatar
United Kingdom
9
Drives: E93 330d M Sport Auto
Simon,
I have same car as you (56 plate) and I tend to top my oil every 8 weeks. I have gone through about 2 litres in the past 16 months as top up only. It's done 30K but to be honest it's using less now than it was last Year?
Halfords sell the oil you need. Castrol Edge OW-15 I think but check your manual. It's pricey at around £14 a litre.
I would avoid an oil change at the dealer if at all possible unless it's in for a proper service too. They will charge circa £100 for supply of the oil alone. You could however buy your own and insist they use that - some customers do this.
Not sure exactly how much oil the engine takes but reckon you'll need around 5 litres - this will be in car manual too.
PhilR
      07-08-2008, 02:54 AM   #4
Jude1
Jude1's Avatar
United Kingdom
29
Drives: 3 Series
Originally Posted by PhilR View Post
Simon,
PhilR
Hi Phil,
You are more than likely using 0w-30 and not 0w-15. Your oil useage also appears to be quite high though.
Jules.
      07-08-2008, 04:51 AM   #5
rogerxp
rogerxp's Avatar
United Kingdom
165
Drives: M3 Comp Pack / QQ+2 Tekna
I'm about to sound a complete novice here but my 330d is my first ever deisel - should I be putting more oil in it compared to a petrol??? Only had the car 9 weeks, it's an '06' Manual on 40k (bought on 39k), but I hardly do any mileage. I presume the car will tell me when it's thirsty???
Current -: MW E92 M3 Competition Pack / Qashqai+2 Tekna 1.6dci
Gone -: 370Z GT Roadster; BMW X3 3.0d xdrive M Sport; E46 330i M Sport Coupe; Mazda RX8 231; Nissan 350Z GT Roadster; BMW E90 330d M Sport; BMW E92 335i SE; Maserati 4200; Nissan 350Z; Honda S2000; Astra Coupe Turbo; Ford Probe
      07-08-2008, 05:51 AM   #6
Jude1
Jude1's Avatar
United Kingdom
29
Drives: 3 Series
On the 335d you have to check the dipstick, whereas on the 335i the on board display notifies you if the oil is low. I would say that the 330d is the same as the 335d.
In the "olden" days then the diesels used to use a fair bit of oil, nowadays the useage is comparable with petrol engines. I thought mine would use more than it has but at 30k in 12 months it's used about a litre or so.
Jules.
      07-08-2008, 05:56 AM   #7
330cdsport
Right Responsible
330cdsport's Avatar
United Kingdom
58
Drives: AW F21 M135i
I have put about a half litre into my car (335d) and it has now done 8.5K in just over a year. I did drive it hard from day one and supposedly this helps it to bed in better and use less oil.
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe, F10 535d M Sport.
Current: AW F21 M135i, Coral Red, Pro Nav, Vis, HK, & Clunky Adaptive Suspension
Current: F15 X5 XDrive 40d M Sport - Space Grey, lots of toys.
      07-08-2008, 09:25 AM   #8
PhilR
PhilR's Avatar
United Kingdom
9
Originally Posted by Jude1 View Post
Hi Phil,
Jules.
I stand corrected Jude, it is 0W-30 (not sure where I got the 15 from). I thought the oil usage was high too, even for a diesel. It has slowed of late though and not put any in for the last 8 weeks or so. Maybe the remap has something to do with this?
I've done 22K in 16/17 months and added 2 litres. Bought a gallon of it 2 months ago and not had to use any since - sods law
PhilR
      07-08-2008, 09:31 AM   #9
Jude1
Jude1's Avatar
United Kingdom
29
Drives: 3 Series
PhilR
That sounds ok. No engine is the same so useage may vary, plus it sounds like it may have stabilised a little now.
Jules.
      07-08-2008, 10:33 AM   #10
simonbenn
Hi,
Thanks for the responses. It appears that there are 2 common oils approved that meet the BMW LL-04 spec. There are others..
Castrol Edge 0w30 : This is what most of the internet says is recommended for the 3.0d
Mobil 1 ESP 5W30: This is what the service guy at BMW says they use.
So the current price is 44/47 at halfords (groan) and I suspect I need a full 6.4L. Any better deals out there? I can't rely on the internal mail service delivering this stuff, so will have to collect it. PITA.
Still looking for the relevant scans of the manual. Anyone?
Simon
      07-08-2008, 11:29 AM   #11
Jude1
Jude1's Avatar
United Kingdom
29
Drives: 3 Series
Simon,
The manual states:
Diesel Engines
Preferred: BMW Longlife-04
Alternatively: BMW Lnglife-01, BMW Longlife-98 or ACEA A3/BA
BMW Recommends Castrol.
It doesn't mention anything about grades.
The important thing is that as long as it meets the aboves criteria it should be fine, with Longlife-04 being the preference, with this in mind then both of the oils you've mentioned are fine, some Dealers are now also using Halvoline and the Comma oil mentioned in the link above is also fine.
There are also the following oils if you can source them:
Motul 8100 5w-40 LL04
Motul 5w-40 LL04
Fuchs Titan GT1 5w-30 LL04 (same as Texaco Halvoline)
Hope this helps,
Jules.
      07-08-2008, 11:43 AM   #12
simonbenn
Thanks Jules.
So I've just found a stockist of the Comma Syner-Z 5w30 locally to me and he's open until 7pm. He's asking £38.50 for 5l as opposed to 47 for 4l. Much better. If I find any other prices of note I'll just keep adding them for reference in the future.
Regards,
Simon
Reply
e90post
