She struggles when starting
10-28-2018, 05:05 PM | #1 |
Rep 74
I was away for two weeks and she sat in the underground parking nice & warm. Since I've been back, it seems that first start of the day is difficult. It's like 3-4 seconds to turn her on whereas normally, it's instant. The rest of the day it starts normal.
On a related note, the other day after a 20 min drive, I could hear an electrical hum from the battery. After 3 years of ownership, this was a new sound. Some UFI: My positive battery lead is unplugged / broken (the thing that disconnects the battery in an accident.) It's been looked at by my shop. New part is like $500... I digress. So back to the original question, does this sound like a battery issue or potentially a starter issue? I just returned from and expensive trip abroad so it would be awfully frigging timely to do a cheap starter fix. Battery has warranty with my local shop. Thanks in advance.
Some days you're the pigeon, some days you're the statue.
2006 330xi E90 / First time owner |
10-28-2018, 05:55 PM | #2 |
Rep 486
Check the voltage with the car off. Either at the battery or by using the hidden screen.
Then check the voltage when the car is on. If the voltages are within the correct range. It is most likely your starter. |
10-28-2018, 05:56 PM | #3 |
Rep 679
our cars use energy even when parked unattended...continually.
its a small amount, but it will drain the battery over time. My E91 needed a quick charge after 3 weeks on the lift...... my battery level was down below 12v when I checked it with a multi meter. its a very simple test. check the battery voltage when the car is at rest...and then check it again when its running. If the alternator is charging correctly, you will get readings above 13v and below 15v.....these readings may fluctuate when its running. This is fairly normal. when the car is at rest, a healthy battery will be above 12 volts. (12.5 is good, 12.7 is great) you can check at the battery terminals, or up at the jumper cable connections under the hood. its actually good to check both places to be sure at rest readings and running readings are pretty close in both locations. a multimeter is under 15.00 at any parts store.....even walmart.... what Im getting at to answer your question is that the slow start was probably due to the car sitting idle for a while. Now, the battery noise is not normal. what type of noise? clicking, rattling, humming, crackling? those would not be so great! JP |
10-28-2018, 06:05 PM | #4 |
Rep 74
Was a humming noise comparable to 60 cycle hum. I have iCarly so I will check now.
10-28-2018, 06:40 PM | #5 | |
Rep 74
Icarly would not read the voltage with the car off. I did find an old voltmeter that I inherited, it read 12.5. Having never used one can you verify if my settings were good. http://www.directupload.net/file/d/5...v7jpba_jpg.htm Last edited by BIMGUY; 10-28-2018 at 06:47 PM.. |
