Water/coolant in the driver door footwell
11-01-2018, 02:33 PM | #1 |
Rep 774
So I got a low coolant warning sign , just topped it off with distilled water and within hours the driver footwell is soaked with water. Could else here misting trickling water when driving with ac on? Cant see any visual leaks, also took the undercover off and left the car idle for 30mins . No drips on the floor, any suggestions?
Else the car has not been washed or drained on fyi. Last edited by 46m3csl; 11-01-2018 at 02:45 PM.. |
11-01-2018, 02:45 PM | #3 |
Rep 774
11-01-2018, 02:48 PM | #4 |
Rep 2,758
12-02-2018, 06:14 PM | #7 | |
Rep 4,088
Would need to carefully remove/cut away that hose (when you have a replacement available), and carefully inspect the tube/ fitting the hose is mounted on for any cracks or fatigue. With any luck, it is brittle plastic which can be reinforced by good epoxy like JB-Weld, without having to remove the old core. NOT the easiest thing to access -- hope you're lean, mean and ambidextrous. Here is the TIS Procedure for replacing the "Heat Exchanger:" https://www.newtis.info/tisv2/a/en/e...ntrols/PIXPIwK George |
