Driver Heated Seat not working
11-04-2018, 01:05 AM | #1 |
Rep 307
Recently, my driver's side heating module stopped working. When I push the warmers, the lights will appear for a second and you can hear a click but then it immediately shuts off. The passenger side works perfectly fine. I've seen a few threads about this same problem but I haven't really found a solution on those threads. Hoping someone can help me with it as it's almost winter and the mornings can get a little cold.
11-04-2018, 01:34 AM | #2 |
Rep 2,773
you'll need to remove seat, check all seat heating connectors and if this will not help, disassemble seat to see if heating mat have any breaks
11-04-2018, 01:55 AM | #3 |
Rep 307
damn I was honestly afraid of having to take the entire seat out lol. so when I do, I'm supposed to just look and see if all of the seat heating connectors are fine and still plugged in correctly? and then move on from there?
11-04-2018, 03:35 AM | #4 |
Rep 13,122
You can tip it back to inspect the bottom .
after removing the rail fasteners Typical problem is broken wires from moving back and forth. Also if you remove connectors with the battery attached you will incur a air bag error that requires external resetting the error by a Scanner or BMW software and cable . https://www.e90post.com/forums/showthread.php?t=192819 |
11-04-2018, 10:02 AM | #5 | |
Rep 307
