11-14-2018, 07:37 AM | #1 |
S0THPAW
8750
Rep 7,852
S55 with OPF cooling fan
After normal driving when I put the car in my garage the cooling fan/system stays on for 10-20 seconds or so.
Normal temps outside(8-15 degrees Celsius) N55 in OG M2 never did that after normal driving in normal temps. Yesterday I didn't even drive very fast or something and let it (driving @ lower revs for a few mins like I always do) cool down just for te sake of it. I put it in my garage and there was it again: the cooling/fan. But now it took about 3 mins and then it stopped, so strange. That's a lot of cooling and it was about 7 degrees Celsius outside. Is this normal for this kind of S55? Cheers Robin |
11-14-2018, 02:04 PM | #2 |
Rep 3,256
I noticed the same thing. Turned off the car for the first time in the garage and the fan stayed on for about a minute. Seemed ok but I’m curious as well.
M235i didn’t do this. |
11-14-2018, 02:34 PM | #3 |
Rep 1,262
Drives: BMW 1M
Only happens to me if driving "normally" in sports or sports +. Only stays on for about a minute.
11-18-2018, 12:12 PM | #5 |
Rep 1,237
Drives: M2 Competition
Once you came to stop, just let your motor run for another 30 seconds before you finally turn it off. I also don't push it during the last five minutes, but thats already over the top...
A bad szenario would be to have maximum power for at least 1-2 minutes and then immediately shut off the motor. That's what will cause problems.
12-03-2018, 12:21 PM | #6 |
Rep 67
Turbos need cooling...
When driving for extended periods and then coming to park/shutoff, it’s best to let turbo powered motors to idle for a couple minutes to dissipate excess heat... Or that’s my limited understanding. Perhaps the reason for the engine fan.
12-03-2018, 07:51 PM | #7 |
S0THPAW
8750
Rep 7,852
Since my Impreza GTTurbo back in 1999 I always let the turbo cool off by driving with low revs for the last miles and/or letting it cool down for a minute or so in my garage.
Cheers Robin |
///M Houbi1655.00 |
