Alignment Needed?
03-21-2006, 02:11 AM | #1 |
Rep 1,238
Alignment Needed?
I lend my car to my sister and she curbed the car on a right turn and put a dent on the rim. Sad... I'll look into it and see if it can be repaired... But my concern is the alignment. I don't notice a problem with the car afterwards but should I still have the alignment checked by the dealer?
03-21-2006, 02:19 AM | #2 |
BMW, can I have some LSD please?
88
Rep 1,591
Ouch! Does your car have Active Steering that she wasn't used to?
Alignment or not depends on how it drives. Any vibration at any particular speeds? Also any front wheel mis-alignment is felt more easily because of the feel thru the steering wheel.
2006 330i | TiAg | Black | Al | 6MT | Sports Package | Logic 7 retired
2008 335i | AW | Black | Al | 6MT | Sports Package | Logic 7 retired 2013 328xi | Red | Gray | Al | 8AT | Sports Line | Premium | Executive | Heat Pkg retired 2017 340i xDrive | Estoril | Black | Al | 8AT | M Package |
03-21-2006, 12:42 PM | #4 | |
Rep 275
As for the damage to the rim, theres the cosmetic aspect of course, but try the vehicle over the range of speeds you require looking for vibration. If you get excess vibration, get your wheels repaired and/or balanced. As for alignment. In the UK, I'd go to a specialist tyre dealer not BMW. Look for one with an electronic 4 wheel alignment rig. Only take it to BMW if the tyre dealer says that there are damaged components. Ward - When I used to get my E46 aligned - They would do all four corners. I'd be surprised if the E90 was different. |
03-21-2006, 09:00 PM | #5 |
Rep 1,238
It's the front wheels. The rear wheels are fine and not impacted. Up till now, I don't feel a difference. The steering wheel direction seems to match it's tracking and no vibration felt.
03-21-2006, 10:29 PM | #6 |
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
The dented wheel should be looked at by a wheel/tyre professional.
I certainly would have my dealer look at it as they are set up for this.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
