12-12-2018, 06:09 PM | #1 |
Rep 22
Reliable Ballasts for Aftermarket HID Headlights
About a year or so ago, I bought aftermarket headlights from here.
It worked great for a few months, but since then I've had a ton of problems with my lights. The left or right low/high beams would go out, and sometimes work on occasion. I got new ballasts twice from the manufacturer, and I still have problems with 1 or both low/high beams not working (DRL and angel eyes always work). Does anyone have a link to reliable Ballasts I can switch in? |
12-12-2018, 10:35 PM | #2 | |
Rep 377
Here's a link to the morimoto ones on TRS, just the ballasts. They have a full kit as well. https://www.theretrofitsource.com/am...moto-xb35.html TRS also sells OEM ballasts from denso, matsushita, osram, etc. if you want to go that route.
2014 BMW 328i, 6-speed Prem / Nav / Drivers Assist / Heated Seats / Lighting |
Diddler12.00 |
12-12-2018, 11:56 PM | #3 |
Rep 1,934
+1 for Morimoto ballasts and TRS. Used both for 4 swaps on a couple different cars. Great ballasts, bulbs, and projectors for the money.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
Diddler12.00 |
12-14-2018, 12:28 PM | #4 | |
Rep 22
Do you recommend I code out the low beam voltage monitoring using a coding app, or is it not needed? |
12-14-2018, 07:24 PM | #5 | ||
Rep 377
Diddler12.00 |
12-16-2018, 03:29 AM | #6 |
¯\_(ツ)_/¯
950
Rep 1,762
+1 morimoto
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC |
Diddler12.00 |
12-17-2018, 04:58 PM | #7 | ||
Rep 22
https://www.theretrofitsource.com/ca...reselect=47697 |
12-17-2018, 05:32 PM | #8 | |||
Rep 1,934
Usually you get whatever the OE system used, so you can connect the body harness into the ballast. However, there are many ways to interface that. I've used an adapter in between the body and ballast before, on one retrofit, and other times I haven't. This was just a short piece of wire with the appropriate plugs on either end, eg. H7 to H11.
12-17-2018, 06:54 PM | #9 | |
Rep 22
12-17-2018, 07:44 PM | #10 |
Rep 270
I have the Hylux ballasts. Been going strong for a couple of months.
The only issue I run into with them is when I hit a spot of shade and back to regular light. Idrive will give me an error saying one bulb is out. But if a switch the toggle to turn on headlights, the problem goes away. I suspect the the ballast has an issue with a quick on/off. Other than that, they perform spectacular
2013 328i xDrive | M Performance Exhaust | Injen Intake | DEPO Headlights |
2019 440i xDrive | Muffler Delete | |
chuckles01188.50 |
12-17-2018, 10:20 PM | #11 | |||
Rep 377
Goodluck!
12-17-2018, 10:34 PM | #12 | |
Rep 377
bheng8978.50 |
12-18-2018, 10:07 AM | #13 |
Rep 270
I have not. I'll go ahead and give it a try!
chuckles01188.50 |
01-24-2019, 05:18 PM | #14 | ||
Rep 22
chuckles01188.50 |
01-25-2019, 05:33 AM | #15 |
Rep 308
^ This
2017 F31 328d xDrive
M Sport M Performance |
01-25-2019, 10:51 AM | #16 | |||
Rep 377
