been to my trusty dealer and got info on engine changes
03-21-2006, 06:09 PM | #1 |
Rep 1,055
BMW engine revisions:
e90/e91/e92 3.0NA engine will be produced until end of may 2007 and will then be faced out to be replaced by the 3.0BI-turbo engine. 325i will remain in its current form until december 2007, revision is expected/phase out? 328i introduction in september 2007 , rumoured to produce 230bhp. The saloon will not get more than 306bhp. The talk of a si version are not showing in the bmw catalgoue. 335d expected to ship september , either with a 272bhp or 291 bhp part, yet uncertain. 330d will not be revised until 2008/2009 no plans to revise 320d. I got loads more info on 5 series and 6 series and z4 and so on, if anyone interested. As usual this are estimates in an internal bmw memorandum, so expect changes / alterations.. I hope GregA can confirm most of the details
2007 CLS55 AMG / 2003 BMW 745Li
03-21-2006, 06:12 PM | #2 | |
Rep 996
2006 330i Monaco Blue | Grey | Walnut ...Manual | Sports | Premium | Cold | Nav | Comfort Access | PDC | Sirius | Sunshade ...M-Tec Steering Wheel | M-Tec Shifter | TLC ...Performance Center Delivery | Oct 14, 2005 |
03-21-2006, 06:15 PM | #3 | |
Rep 1,055
3.0 (530i/530xi) litre engine will be produced until end of may 2007 and will then be faced out to be replaced by the 3.5BI-turbo engine. producing 306bhp. No 340bhp part for the standard e60 2.5 engine will remain in its current form until december 2007, revision is expected/phase out? possibly replaced with a 2.8 version producing around 230bhp. 4.8 V8 engine will NOT be changed/replaced until december 2010. Then expect a 5.2engine with around 406bhp (not finalized) 535d will be replaced with a 291bhp part in september 2007 (e90 3 series likely to carry engine first) 530d will not be altered until 2008/2009 Possibly a 540d v8 diesel early in 2009. Expect a big big facelift around may 2007, bmw is really putting a lot of resources into this
03-21-2006, 06:17 PM | #4 |
Rep 1,055
e63
630ci will be dropped and a 635ci will be introduced around june 2007 635d rumoured, yet on the drawing board. 650i unchanged until december 2010 Cosmetic changes in the first half of 2008
03-21-2006, 06:18 PM | #5 | |
Rep 996
03-21-2006, 06:21 PM | #6 | ||
Rep 1,055
03-21-2006, 06:35 PM | #7 | |
///Man of Steel
30
Rep 1,243
Thanks for the update!
03-21-2006, 07:29 PM | #8 | |
Rep 1,055
good point. The coupe will come as 335ci and 325ci only, no mention of a 330ci
03-22-2006, 05:07 AM | #10 | |
Rep 410
325Ci and 335Ci are the first coupe versions to arrive in September. I guess its safe to say that more versions will be introduced later. I also don't think that the 330i engine will be phased out. It's rumored that the 325i and 330i will be changed to Direct-Injection versions later on. |
03-22-2006, 05:32 AM | #12 | |
Rep 996
03-22-2006, 05:48 AM | #13 | |
Rep 1,055
03-22-2006, 11:59 AM | #15 | |
Rep 1,055
03-22-2006, 12:07 PM | #16 | |
Rep 10,185
From March production the E60 has got the new tire pressure system as recuired in all new USA cars by 2009. Instead of just telling you it has a flat, it tells you which one is flat. They have to use the old system of having a monitor in each tire, which makes the system prone to damage, but this is required by the new USA legsilation. So you know which cars conform to the new regulations they changed the MY Other USA models will recieve the system later
BMW if you are reading, I need a job, Please. |
03-22-2006, 12:09 PM | #17 | |
Rep 10,185
The cars will say 325i and 335i on the back
03-22-2006, 12:19 PM | #18 | |
Rep 2,099
03-22-2006, 12:51 PM | #19 |
Secret Agent
97
Rep 496
My info for Germany:
E90/E91: 325d, 335d & 335i added in September 2006 to the existing model line. E92: 325i, 335i, 330d, 335d coming in September 2006. 335si coming in 2007. Also xDrive - new version. E93: coming in Spring 2007 (production starts in December 2006) - same engines as coupe. 635d & 645d are to come in early 2007. E60's "big" facelift has more to do with chasis, not design. New versions of DSC & xDrive will be applied - coming from new X5. New engines also coming. I have no info on power outputs - except 245kW (333HP) for 335si, and rumours 335d coming with 210kW (286HP). |
03-22-2006, 02:49 PM | #21 | |
Rep 7,047
Ok, so the E90 in Europe will no longer be available with a 2.5 liter gas engine? Hard to believe as many Euro countries charge additional tax according to displacement, thus the availability of smaller engines in the Euro market, and why the Euro E90 325i still has the 2.5 liter engine, when the US 325i has a 3.0. There will be a coupe and sedan with the "335i" badge? Seems odd. And, an x-drive coupe? What is an E93? Nevermind, I found out. This twin turbo, it's a gas engine right, or diesel, or one for each? BTW, those turbo's are SO tiny, I almost want to call them "cute". No wonder they say no lag. Those things look like they could spool up from a chipmunks fart. The oil feeder and coolant line look quite large and robust for such small turbo's. That's good for longevity. Any word on the boost pressure? T Last edited by RPM90; 03-22-2006 at 03:11 PM.. |
03-22-2006, 03:15 PM | #22 | |
Secret Agent
97
Rep 496
Read here: http://www.e90post.com/forums/showpo...0&postcount=43 |
