Engine warm up time?
12-14-2018, 06:28 AM | #1 |
Keep it moving
49
Rep 83
My e92 runs fine. But compared to the other cars we have it's very, very slow to warm up.
For reference the needle in the temp gauge in the 4Runner starts moving within 5 minutes. The Audi I had before the 92 was about the same. I see BMW uses a different coolant. VAG motors run a different coolant than the standard green Prestone-like fluid the Toyota takes. By the time I get to work, less than a 10 minute drive, it's just starting to move the needle. I was taking an extended route to get the temp into the 180 range but that takes 20 minutes. Is there something I should look at or does the motor run cool?
In reality I am a 12 year old with no concept of consequences.
12-14-2018, 07:35 AM | #2 |
Rep 300
I don't believe you're looking at coolant but in fact oil temp which will always be slower to heat up.
Things might be a bit different but my MHD gauges for my 335i show coolant shoots right on up but oil lags behind by about 15 minutes similar to what you're describing.
"Wheels and exhaust aren't a build"
Wolf 3352367.00 |
12-14-2018, 07:53 AM | #3 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
you can't compare oil temp to water temp, oil will always take longer and the needle doesn't start moving until 160*f which is more than 'warmed up'. your oil might only be 120*f in your 4runner if it's 'warmed up' based on the water temp.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
Fritzer944.50 |
12-14-2018, 10:28 AM | #5 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
Right when I start the car I'll give it a couple revs up to 5k-6k RPM. That warms it up pretty fast.
BTW anyone ever have any issues with clanking noises coming from the engine when they accelerate?
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
12-14-2018, 10:31 AM | #6 |
945
Rep 1,507
In all seriousness, my N51 takes about 5-10 minutes to get into operating temp from a cold start. I idle for a few minutes and then have a 5 minute drive to the freeway in the morning. By the time I get on the freeway and over into the left lane the car is good to go. It is worth saying that the coldest it gets here is maybe 45-50 degrees Fahrenheit outside, and my garage is generally 10-15 degrees warmer than outside temperature.
These engines do stay pretty warm for a while after an average drive.
12-14-2018, 10:37 AM | #7 |
Rep 3,560
12-14-2018, 10:40 AM | #8 |
Hoonigan
6893
Rep 3,001
Drives: '09 328i, '98 Wrangler
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
Antetokounmpo1551.50 Fritzer944.50 |
12-14-2018, 10:41 AM | #9 |
Rep 151
12-14-2018, 11:09 AM | #10 |
Rep 3,475
12-14-2018, 02:55 PM | #12 |
Keep it moving
49
Rep 83
Duh. I wasn't thinking about the oil. That is a relief because I was worried that because the previous owner only put 36,000 miles on it before I bought it. It's definitely a garage queen now since I put it on a trickle charger.
12-14-2018, 03:05 PM | #13 |
E82 Mudflap Ambassador
2216
Rep 2,219
Drives: '08 128i
These motors have a lot of oil too - 7qts
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
