12-18-2018, 11:32 AM | #2 |
Rep 1,962
I'm under the impression that the PCV is built into the cam cover. So how does either of these options work?
Also, given that the crankcase is designed to run at slightly below atmospheric pressure, what are the problems associated with increasing the pressure in the crankcase? |
12-18-2018, 02:50 PM | #3 |
Rep 538
I have a Mann provent 200 but it's really only meant for low output turbo diesel around 300hp. The next size up is 400 and it's the size of a bathroom trashcan..
12-28-2018, 11:34 PM | #4 | |
Rep 67
12-29-2018, 02:10 PM | #5 |
Rep 538
s55 is direct injected so lack of fuel to back of valves can get gunky after while especially with the pcv pooping into the intake.
The cdi common rail cars had similar issue with intake gunk but due to egr dumping soot combined with pcv crapping oil vapor. Catch can should help along with reaming the car and avoiding short trips which don't allow car up to temp. What catch can are you looking to get? |
12-29-2018, 02:42 PM | #6 |
Rep 7,510
In terms of your question op, I would get a catch can. An atmospheric vented pcv system would cause a few issues:
1) if you're in the USA you won't pass carb or any emissions testing. 2) you'll probably have grease stains under the hood which is annoying imo. Imo I prefer catch cans, or if you must run a catch can but don't have to connected to the intake and have the outlet on the can vent externally. But in this situation you may as well have it connected, unless you don't want to take any chances of oil sucked into the engine. Note you'll get a check engine light venting externally because these new motors monitor vacuum. Also there is a train of thought that having vacuum is good got the crank case and piston rings. |
