tell me is this true
06-24-2005, 02:58 PM | #1 |
Rep 354
go read this link from bmw-forums
http://www.bimmerwerkz.com/forum/ind...ic=39676&st=20 they say they are going to try to retrofit a drain plug on the oil pan!!!! its in the middle of the page i think. so does the e90 have a oil drain plug? |
06-24-2005, 03:20 PM | #3 |
Rep 6,158
it has to have a drain plug
that's the only way to get the old oil out when you change it, of course there's a drain plug Socom, so when you buy a new filter kit it comes with a new drain plug????? My E36 used to come with new seals and o rings, but not a new plug. |
06-24-2005, 05:26 PM | #4 |
Rep 10,185
They dont know what they are talking about
There is a drain plug, but its behinde the splash guard. Just remove the splash guard and you have easy access to the normal drain plug. The tightening torque is also listed as 25Nm |
06-24-2005, 06:21 PM | #5 |
Rep 354
oh thanks for replying so quickly cuse i after i read that i started to look at other cars (infinity,acura, and merc.). having a drain plug is a very important thing to have in my car, i am gonna keep it forever just like my e30!!
06-25-2005, 12:07 AM | #6 |
Rep 137
IIRC, the oil change procedure on new Mercedes models involves the use of a top-side oil extractor instead of lifting the car and using the drain plug. I believe they still have drain plugs, they just aren't used by the dealerships if they are following the factory procedure.
