BMW X5
      02-01-2019, 08:31 PM   #1
SCA
SCA's Avatar
Drives: Multiple BMWs
Arrow FS: NIB Rupes Mark II 21 - random orbital buffer
BIMMERPOST / Classifieds
Asking Price:
USD 375.00
Item Interest
New in Box, never used. Manufacture date June 2017.
Product description. The Rupes BigFoot Random Orbital Polishers are the perfect buffer for any detailing enthusiast or professional! They offer an incredible balance of power, safety and performance that everyone can benefit from. The random orbital movement of these buffers allows you to achieve professional polishing results in less overall polishing time. What previously may have taken several sets of passes can now be done in just one to two sets of passes. The motor is powerful enough that you will never have to worry about bogging down when correcting heavier imperfections, swirls, scratches, etc. Even with the powerful motor this buffer is extremely easy to use. Beginners will be able to pick up this buffer, feel comfortable and achieve significant correction if desired. This immediate comfort comes from three important safety features: soft start, anti-spinning feature, and electronic feedback control. The soft start feature will guarantee a soft acceleration when you squeeze the trigger, while the electronic feedback control will maintain a constant speed while polishing. Once you reach higher speeds the anti-spinning feature will help prevent holograms and burning that can come from high speed buffer rotations. Another great feature of these buffers is that the backing plates come built in and feels solid, so it will never come flying off! All these features means it is incredibly safe and easy to use, but experienced professional detailers will also love this unit. It has the perfect blend of safety and speed that allows you to polish incredibly fast while leaving minimal haze. If you are looking for the perfect buffer for your detailing work, check out the Rupes BigFoot Random Orbital Polishers!
Use these buffers with any pad you'd like. We recommend the Foam & Microfiber Pads from Rupes!
MarkII 21
Should be used with 6"-7" pads
Utilizes a 21mm throw or orbit
Designed with professionals in mind where you want to polish large surfaces in a shorter amount of time
120 volt, 60Hz, 500 watt motor
RPMs: 2500-4700
Features a stronger, reinforced housing
Built in 6" backing plate
Rubber inserts inside, improve handling and comfort
Asking $375.00. Buyer pays for shipping.
xbimmers
