02-10-2019, 03:33 PM | #1 |
Rep 67
Engine light on
Hi guys I got this light on my i3 Rex. 2105 about 20g miles I been looking online if theres anything related but most of the post I found was could be a bug on software, on any case I'm open to hear if anyone in here has the same issue
i3 HANDY MOVIL
02-11-2019, 10:34 AM | #2 |
Rep 47
The check engine light is most likely related to the REX. Do you have a code reader to extract the code that is setting off the light? You need that to be able to understand why the light is on. If you use Bimmercode, your OBDII plug in should help you read the code however, you might need to download another app to read the code and even clear it.
I had a check engine light about 8 months ago but it was related to the gas cap not being tight. |
02-11-2019, 10:47 AM | #3 |
Rep 427
My engine light came on and it was for the REX oil change. I had the dealer complete the change (covered maintenance) and no longer have the light. If you have the BMW app you can see the service required.
2013 X3 3.5i AW,Msprt,rear fogs,PS,CP, Tech, etc...
Other cars 2005 S2000 2018 i3S |
02-11-2019, 10:51 AM | #4 |
Rep 67
I did get a code reader on it but I look it up online and all about a Malibu car nothing of i3 bmw
i3 HANDY MOVIL
02-12-2019, 10:35 AM | #5 | ||
Rep 2,561
At first, I would get them read/reset at the dealer. Later on, I ignored them (leased car) and they would clear on their own after X-many ignition cycles. Yours could be similar, or could be something serious. Quote:
The generic stuff above is failing to read/interpret BMW codes. You could try resetting them, and see if they come back. That would be one way to confirm if the issue is ongoing, or was something spurious. HTH, a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
02-12-2019, 10:37 AM | #6 | |||
Rep 67
Thanks
i3 HANDY MOVIL
