E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > K&N air filter..worth it?
Reply
      03-24-2006, 02:09 PM   #1
BellasBmw
If love is the answer,please rephrase the question
BellasBmw's Avatar
Drives: Tit Silver 325i
2006 325i  [0.00]
I was thinking about going and purchasing one.. Ive heard it increases power due to the air flow..etc. I have about 8000 miles on my car, should i wait, or what the heck.. go and get it?
~*~BellasBmw~*~
Proud mama to 325i/TiAg/Black lette/Pwr seats/Sirius/Sport/Walnut/Step/Xenons/Chrome exhaust/20% tint
      03-24-2006, 02:14 PM   #2
irowharderthanyou
irowharderthanyou's Avatar
25
Drives: 330i TiAg
I could be wrong, but I heard that these air filters put out such a small power increase (<1hp) that you wouldn't even notice the extra power.
2006 330i TiAg - Beige, Step, ZPP, ZCP, Sat. Prep.
      03-24-2006, 02:31 PM   #3
brian32e
brian32e's Avatar
16
Drives: '06 Alpine White 330i ZSP
yeah, it's not really a performance mod. just means you don't have to replace your filter with a disposable one.
      03-24-2006, 02:32 PM   #4
BellasBmw
BellasBmw's Avatar
2006 325i  [0.00]
is it worth the money.. i mean will i get a noticiable amount of power?
~*~BellasBmw~*~
      03-24-2006, 02:38 PM   #5
irowharderthanyou
25
Drives: 330i TiAg
No to both
      03-24-2006, 02:42 PM   #6
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
thank you. now I won't worry about this either.
"Teach the ignorant. Ignore the stupid."
      03-24-2006, 02:46 PM   #7
shragon
Moderator
shragon's Avatar
http://www.bmwe34.net/e34main/upgrade/Air_filter.htm
read the part by jim conforti.
      03-24-2006, 02:46 PM   #8
shadye90
shadye90's Avatar
60
Drives: BMW Fanatic
Truthfully Bella, I installed it into my car and the only difference I felt was in the sound, which btw sounds awesome!!(I also removed the silencer tube attached to the airbox) The drop-in K&N really wont give you a HP increase and also remeber that the Charcoal filter is right behind it too..If you remove that filter also then you'll feel a little power increase(I removed mine already)
1988 E30 M3
Diamantschwartz/Black
      03-24-2006, 02:49 PM   #9
Squawks
One of my two dachshunds:
Squawks's Avatar
Drives: B6 A4 3.0 Quattro
Not worth the money. You will never notice the power increase as it is so minor it's negligible.
Even though you don't have to replace it with another filter, it uses the ancient technology of cleaning the filter and then re-lubing it with a special kind of oil. I wish I didn't get the K&N and just stuck with disposables. Hell, the cleaning/lubing is not even worth my precious time anymore compared to buying those cheap $15-20 filters.
I'm sorry about my outlandish behavior - there's too much blood in my alcohol system.
      03-24-2006, 02:53 PM   #10
england1987
Drives: Z4 M coupe
2006 Z4 M Coupe  [7.50]
They are better than stock air filters, but BMW air filters are good ones to start with. I would change the filter anyway because they are cheap and are reusable. I put one in my Jeep, I can't tell a difference, but I satified knowing that the filter is better than stock.
Check out K&Ns website for airflow charts
      03-24-2006, 04:12 PM   #11
ben1364
Drives: E90 330iA
If what you say, "...better than stock..." is true, please supply data.
Thanks.
      03-24-2006, 04:39 PM   #12
Bimmerista
Bimmerista's Avatar
Drives: superstock
K&N filters allow more air and also more dirt through-so they are not "better" than stock from that perspective. They do (marginally) improve performance, but require regular cleaning and replacing at higher intervals to keep the performance levels up.
For this reason I have never used one. If you want a (relatively) cheap performance enhancer get an Eisenman (or equivalent) exhaust
      03-24-2006, 05:02 PM   #13
SCA
SCA's Avatar
Drives: Multiple BMWs
Another vote for a waste of money.
      03-24-2006, 09:15 PM   #14
dom1
dom1's Avatar
Drives: 2006 330xi
I have it in my wife's Expedition and it did two things... Jack and S..T, and Jack just left town. I initially thought I was getting better mpg but I think it was my desire to justify the $50 I spent. I cleaned it once and found that the glue that holds the sealing ring to the filter was not good so it was not creating a good seal. After cleaning, I added oil and later found out that I added too much :mad: Summary, K&N filters suck and will never buy them again.
2006 330xi MB, Terra, Burl Walnut, Auto, PP, Nav, Heated Seats, SP w/18in
2002 Acura MDX - wife's ride
2000 Ford Expedition Eddie Bauer 4x4 - wife's SUV retired after 120K miles and lots of problems
1994 Pontiac Sunbird 4 cyl. - retired after 170K miles
      03-24-2006, 09:30 PM   #15
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
Drives: 2006 E90
more airflow.....translates to VRRRRRR....engine sound....
but you gotta clean it like every 6 months.....then oil it down....
i personally think it's worth it.......
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
      03-25-2006, 12:19 AM   #16
Drugfranbs
Drugfranbs's Avatar
Drives: Nothing...Yet
But wouldn't such an air filter be more of an advantage to say...the mustang?
      03-25-2006, 09:52 AM   #17
Hej
Drives: '06 Black Sapphire 330i e90
I bought one when I first got my truck, so I can't really vouch for the before & after power. It's mostly been handy from the perspective of not having to change the air filter as often. And as far as the claims go of letting more dirt in, I'm not sure I agree. Seems like the oil stayed very clean for quite a while with my truck.
      03-25-2006, 10:27 AM   #18
M3ti Compact
M3ti Compact's Avatar
Drives: E36 318ti, E90 325i
1995 BMW 318ti  [0.00]
2006 BMW 325  [0.00]
OK...no matter what, the K&N flows better, which will mean some increase- at the least, an increase in throttle response- the tradeoff is filtering is not as good, and you got to take care of it once in a while.
It's the same as buying a suspension- you'll increase handling but tradeoff is ride comfort.
K&N didn't make their name commonplace amoung all auto enthusiasts by selling crap filters.
      03-25-2006, 10:55 AM   #19
underDAWG
Drives: E30 on Stands
Miss BellasBmw,
If you opt for KN filter, you may as well use your old panty hose or stockings. Trust me, your hose will do a better job than KN junk.
1. No cost to you.
2. Less restriction than KN filter, but just as good as KN to let all particles into your BMW.
3. You don't need to wash the filter. I am sure you have plenty supply of stockings.
All jokings aside. KN filters are for race cars and not for consumer cars. If they are so good, why there is not a single car manufacture uses KN filters on their production cars.
Well..... This is a big country, suckers are born every day.
Cheers.
      03-25-2006, 11:20 AM   #20
ben1364
Drives: E90 330iA
M3ti Compact wrote in part, "...K&N didn't make their name commonplace amoung all auto enthusiasts by selling crap filters."
Correct on the first part. The purveyors of K & N filters made their name for 1930s technology commonplace through very effective advertising and product placement.
      03-25-2006, 11:21 AM   #21
BellasBmw
BellasBmw's Avatar
2006 325i  [0.00]
Originally Posted by underDAWG
Miss BellasBmw,
1. No cost to you.
Cheers.
IF someone hasnt yet already.. but posting a DIY would be great. Maybe i can try to use my old pantyhose.. hmm..
~*~BellasBmw~*~
      03-31-2006, 02:12 PM   #22
BMW0
BMW0's Avatar
Drives: AW E90 330i
2006 330i  [0.00]
Bella get an HKS neon green honeycomb filter made of micro foam. I felt the accelerator pedal less heavy and easier for the engine to breathe plus I heard the engine roar more enthusiasticlly. It really didn't feel like the car was much faster.
330i 6MT l 255 HP @ 5900 rpm 214 lb-ft Torque @ 3500 rpm l Alpine White l Beige l Aluminum l ZSP l 494 l PDC
"Freude am Fahren" = "Joy to Drive"
Reply
e90post
