03-02-2019, 09:39 AM | #1 |
///MYK
111
Rep 133
HELP PLEASE Transmission failed while flashing GTS transmission from Bootmod3
Hello.
I am a newbie when it comes to tuning or flashing tunes and usually get help. recently I've become comfortable flashing my M2 from Bootmod3.net. I previously faced no issues going from stock to stage 2 and back. Also, I tried the GTS transmission flash through OBD (which I loved). A couple of weeks ago I returned my car to 100% stock including the hardware. And today I was planning to go back to stage 2. I installed the Downpipe and charge pipe and tuned the car to stage 2 as usual without any issues. The only thing I did different was configure the OTS map to have a lower RPM cold start. After flashing without issues I tried to flash the GTS transmission and it failed. I tried going back to stock and that also failed. I think my car does not have neither stock nor GTS tune now. I cleared errors in diagnostics, reset ECU, went back to stock tune and then tried to flash the transmission back to stock, also with no avail. I tried everything and it won't work. my car starts but transmission doesn't work, its stuck in neutral (P?). Someone please help me. I don't think its a connection issue or battery because I managed to go from stock to stage 2 and back a couple of times, it accepts the tunes without issues, except the transmission. Thank you, |
03-02-2019, 09:45 AM | #2 |
Rep 1,237
Drives: M2 Competition
Do you have a 60A+ power supply connected while flashing?
03-02-2019, 09:57 AM | #4 |
Rep 1,237
While flashing ECU's you should always have a VERY beefy power supply connected. Problem is that they can brick if a voltage drop happens during flashing. So it could be too late already.
I would definitely try flashing the transmission again while having at least a 60A psu connected, if available better 70A or even 80A. Definitely worth a shot!
03-02-2019, 10:11 AM | #5 | |
///MYK
111
Rep 133
kosti36512.00 |
03-02-2019, 10:18 AM | #6 |
Rep 1,237
At least the engine ECU's are pretty picky... voltage drop during flashing can destroy them.
I could imagine other ECU's don't like voltage drops during writing operations as well. Also check all info's abou that ECU you can find. Might be there is something „unusual" needed to successfully flash it? I once had an E39 M5 stuck in my garage for three weeks. I thought i killed the ECU but actually it was „by design" that a particular other ECU had to be disconnected to successfully flash it, so all was good in the end...
03-02-2019, 05:00 PM | #8 |
Rep 8,972
OP have you raised a support ticket on BM3 support page?
I think they need to advise you. Yes as mentioned (and as stated by BM3 instructions) you should have a battery charger connected when flashing dme etc. 5 Amp is fine, I use CTEK 5Amp charger, you're not starting the engine with it, just keeping volts stable. |
03-04-2019, 10:52 AM | #10 |
Rep 2,505
So what was the resolution on this issue? Did you get the transmission fixed?
2019 M2 Competition- October 2, 2018 ED
2011 BMW M3 Sedan Alpine White Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD** |
03-05-2019, 12:43 PM | #11 |
///MYK
111
Rep 133
Hello everyone. It’s been a frustrating couple of days. Got some great support from BM3 and they spent a good couple of hours with me but without luck. Their servers keep showing that i have bad internet. I tried 3 different routers/ISPs. Then one last try with good internet, a charger and after resetting the DME it worked! I now have a stage 2 tune flashed with stock transmission. Too scared to try again the GTS transmission mod. I think I will keep it for a couple of weeks because I have a track day coming up then will bring the car back to stock.
On a side note, I don’t have an intercooler installed and Kuwait is quite a hot country. Current mods are Downpipe, charge pipe and intake. While the recommended hardware for stage 2 is Downpipe and intercooler (FMIC). Should I be concerned or is it okay? |
03-05-2019, 01:24 PM | #12 | |
Rep 1,899
03-06-2019, 02:34 PM | #13 | |
Rep 6,638
03-06-2019, 08:57 PM | #14 | |
Rep 932
08-01-2020, 11:51 AM | #15 |
Rep 85
OP, I was hoping you could elaborate on your troubleshooting. I am currently in the same boat. I tried flashing from GTS to stock and it fails when it tries to clear codes from the ECU. Like yours, It will turn on but its stuck in P. I do have a trouble ticket in with PTF’s but I figured I’d take the weekend to troubleshoot on my end. The battery is holding at 12V with a 30A boost, norton and windows defender are disabled, my router is about 20 feet away from the car, running OBD agent of 20.005. I’ve flashed many times before with no issues. What do you think was the final solution to get your flash to take. Thanks in advance.
08-06-2020, 10:28 AM | #16 |
Rep 2
Hey mrkmtchll , any progress from your side? In the same boat here. BM3 is saying it is probably battery (I wasn't using a charger). However, I had flashed a map just before without issue, but the GTS transmission failed. Annoyingly I can't drive the car anywhere now. Considering get it towed to a shop. Let me know how you got on please!
Cheers |
08-06-2020, 07:26 PM | #17 |
Rep 506
Isn’t the GTS transmission flash meant for older vehicles 2018 and older?
I thought the CS transmission flash is for the 2019 and up DCT vehicles?
2023 X3 M40i @b58x3
2020 M2 Competition @s55m2 |
11-30-2022, 11:10 PM | #19 | |
Rep 3
12-02-2022, 08:39 AM | #20 |
BimmerPost Supporting Vendor
24427
Rep 191,342
Get the CSF intercooler.
09-08-2023, 07:30 AM | #21 | |
Rep 11
He offered to do it remotely for me but I did not have the equipment laptop etc I met him in person and he had my car going into gear and everything fixed within the hour. Hopefully helps someone else out in the same boat as I was. Here’s his contact Number/WhatsApp +44 7398 936603 |
