Any owners of 335D SE with standard 17" alloys do me a favour?
08-04-2008, 03:38 AM | #1 |
Rep 32
Hi,
I'm having some issues with regards to the rear ride height of my 2008 335D SE following an accident that damaged the rear suspension. According to the BMW specs I've seen the ride height is wrong and out of spec (when I measure it) at the back to such an extent the car seems to lean to the drivers side. According to the BMW specs, the ride heights for my car with standard 17" alloy wheels (and run flats) should be Front 591mm Rear 567mm With a tolerance of +- 10mm and +- 10mm side to side My car heights are around the following (note they change slightly depending on if the car is cold or hot (i.e. after a run) N/S/F 596 O/S/F 589 N/S/R 593 O/S/R 578 The fronts are in tolerance, but the rears are both out of tolerance individually and when looking side to side they are also out of tolerance (15mm). This is measured using a tape measure from the bottom of the middle of the wheel rim to the bottom of the wheel arch lip. No preconditions are given and I have tried with both a full tank and nearly empty tank without too much change. The bodyshop are now saying that the car has to be fully loaded for these measurements now....and the've measured other cars with a similar variation. When they put the car on the KDS they are always in spec because the limits are -20 to +40mm.......a 60mm variation! Anyone else had there's KDS'd...do you have the printout? What I would like to ask is if any owners of this car could take a couple of minutes to measure their car's ride height and let me know the results. My car is also prone to drift to the left when you let go of the steering.....not violently but gently over a distance at speed. But then sometimes will do it to the right. I drove another 335D and this was the same but perhaps not as bad.....is this a common trait as well, or just variation in the suspension geometry setups. Sorry for the long post.....its just I'm getting pissed off now with BMW.... Cheers Sean |
08-04-2008, 03:43 AM | #2 |
Rep 1,557
Sean if its the same as the E46 the drivers side always sits lower due the battery being on this side and the car being primarily designed for LHD. I can`t remember if my E90 was the same `tho.
08-04-2008, 04:17 AM | #3 |
Rep 379
Sean, I've got the 18" wheels, but I'm happy to help if I can, after all it seems that it's the difference from one side to the other that you're concerned with.
Where exactly are you measuring from? Any chance of a picture?
2018 G30 520d M Sport with M Sport Plus - Mediterranean Blue
Previously: 2015 F32 430d M Sport, 2012 F10 520d M Sport, 2009 E92 320d M Sport, 2006 E92 335d, 2004 E60 530d, 2000 E39 525d, 1997 E39 523i |
08-04-2008, 04:31 AM | #4 |
Rep 32
RedMax,
The ride heights for 18" wheels are fronts 603mm and rear 580mm. If you look at the wheel, find the lowest part of the rim (closest to the groun) and hook the end of your tape measure to that and pull the tape up vertically so it passes through the centre of the wheel and take the measurement at the bottom of the wheelarch lip. I'm going off the outer curved edge of the lip and not the inner part of the lip (though BMW info doesn't provide any more detail than this). Does that make sense? Many thanks. |
08-04-2008, 04:33 AM | #5 | |
Rep 32
I can visually see the difference between the gap on the NSR wheel arch and the OSR wheel arch and even the Service manager didn't think this was right....though he never seemed to offer his expertise to the bodyshop as he suggested he would.... |
08-04-2008, 04:38 AM | #6 |
Rep 1,557
LOL, its a well doccumented fact on the E46 both my saloon and `vert had it (`tho only aroun 10mm) the only way to dial it out is to fit height adjustable susp. I can`t remember if my E90 was the same `tho, I`d be surprised if its not.
08-04-2008, 06:42 AM | #7 | |
Rep 379
N/S/F 612 O/S/F 606 N/S/R 588 O/S/R 582 So a little lower on the driver's side, not quite as much as yours. Mine's done 28K miles (mostly with me in it alone), if that makes any difference.
08-05-2008, 04:13 AM | #9 |
Rep 2,811
Drives: Jaguar XE P250 HSE
I posted a while ago about mine which had an obvious height difference on the rear wheels, one side being 17 to 25mm higher than the other side. The dealer measured it and claimed the difference was 9.5mm - within tolerance. Over the months since, it seems to have settled down a bit and isn't so obvious. The only thing that had been done to it was a change from 17" to 19" wheels.
08-06-2008, 04:28 AM | #11 |
Rep 32
08-06-2008, 04:57 AM | #12 |
Rep 1,557
As I said I doubt the Left and Right will ever be the same but yours does seem a little too much out, have they replaced a damper or spring at the rear only on one side ? If so it`ll need a little time to settle.
08-07-2008, 03:08 AM | #13 |
Rep 32
They've replace all 4 arms, hub, bearing, wheel & tyre.....the damper and spring are probably the only two items they haven't replaced...... Its done about 1000 miles now, but has been back in 3 times...
08-07-2008, 01:03 PM | #14 |
Rep 1,386
Drives: Jaguar XF S
On standard 17" wheels (flat but compacted gravel surface), my readings were
OSF - 595 NSF - 600 OSR - 575 NSR - 575 For the record left fuel tank had 20 litres in it and the right fuel tank was 31 litres and the car has covered 25,000 miles
Going out with a BAN now that the forum has become Chav Ville. Fair well the early adopters.
Jaguar XF 3.0D S Gone: E92 335d Last edited by jwbmw; 08-07-2008 at 02:18 PM.. |
08-07-2008, 03:46 PM | #15 |
The Tarmac Terrorist
951
Rep 29,345
Drives: 997.2 GT3
where are you measruing to and from? i want to check mine.
997.2 GT3
08-07-2008, 06:19 PM | #16 |
Rep 1,386
Drives: Jaguar XF S
Explained in the opening post carlos
Jaguar XF 3.0D S Gone: E92 335d |
