05-10-2019, 01:48 PM | #1 |
Rep 4
Angel Eyes Not Working When Switch From Low Beams
Hey guys,
I have a weird issue. My 2013 335i will run angel eyes just fine if switched to manual daytime run or in parking lights, but whenever I switch them manually to low beam or if the car is in auto mode, the angel eyes will not flip back on until I restart the car again. This sounds confusing but basically if I have the car in auto and its daytime then I go through a tunnel and the low beams flip on, then I exit said tunnel where it is bright again, the angel eyes do not come back on until I turn the car on and off again. I was told maybe a sensor, but the lights react perfectly fine to light changes, meaning if its dark they flip right on, and if its light they turn off. So I don't think there is an issue there (maybe). Both Angel eyes light up perfectly fine. Its like the car just doesn't want to turn the angel eyes back on after low beams have turned on and then turned off. Any suggestions? Coding? |
