04-01-2019, 02:37 PM | #1 |
Rep 131
Tow hook license plate mount?
Does anyone know if these are available for the M340i w/sensors?
My "go to" shop has not replied to my email query and I'll be damned if anyone at the dealership is going to take a drill to my baby when it arrives. Still calling around, and if I hear something I will update the thread. |
04-01-2019, 03:23 PM | #2 |
Rep 2,760
Drives: 2020 M4 ZCP / 2023 X3 M40i
Just contact the manufacturers. I would get in touch with US Mill Works directly. www.usmillworks.com
04-01-2019, 10:37 PM | #3 | |
Rep 1,077
i have one of these for an f30. and it would set off the park distance control sensors right near the tow hook hole. I hope they have figured out a way around that |
04-01-2019, 11:56 PM | #4 |
Rep 44
Drives: M535,328i,328d,330i
Spoke to my CA he said they would set off sensor. Suggested I put tape over sensor. I ordered the toe hook license plate mount anyway. Will probably remove front plate.
04-02-2019, 07:47 AM | #5 |
Rep 2,760
04-05-2019, 02:33 PM | #6 | |
Rep 131
04-05-2019, 02:37 PM | #7 | |
Rep 131
Unless they add multiple sensors spaced 6 inches apart.... In either case I have been clear with my CA, NO FRONT PLATE! |
04-05-2019, 02:38 PM | #8 |
Rep 131
USMillworks had a great rig which was perfect on my F30 (2014 335i MSport w/PDC). If you got the wrong model then it wouldn't mount in the same position and would not have been fun.
05-27-2019, 08:56 PM | #10 |
Rep 320
I found a universal one on Amazon. The F30 ones will work on the G20, at least the tow hook is the same.
You want to beware and find one where you can screw the bracket as far to the left side of the car as possible, otherwise your front sensors will be blocked and it will trigger every time light shines on the plate, reflected onto the sensor. So, preferably one with plenty of holes on the bracket piece. If you want to see pictures, go visit my IG account. (g20beam) |
06-06-2019, 04:14 PM | #12 | |
Rep 274
https://www.bmwpartspros.com/partloc...catalogid=8798 |
PARTS@STBMW2701.50 |
06-16-2019, 12:06 AM | #15 |
Rep 131
US Millworks towhook license plate mount won’t fit - which one will?
I tried to use a kit for the G20 from US Millworks, as their quality is awesome and I used to have one before. Unfortunately, on the G20 the towhook bolt is too short to clear the bumper fascia.
Has anyone found a license plate mount for the M340 that fits? |
06-21-2019, 10:31 AM | #16 |
Rep 7,433
I purchased the Rennline bracket for my M Sport and it clears but interferes with the parking sensors. I've disabled the sensors from automatically activating so that it doesn't beep while driving but it's still a bit of a pain
https://www.ecstuning.com/b-rennline...e10701340~rel/ |
06-23-2019, 07:58 PM | #17 |
Rep 3
https://www.amazon.com/dp/B07PMLY2CH..._S5beDbV8FBF0Y
I have mounted this one , fairly simple to do but i’ve yet been able to adjust it so that it doesn’t trip the PDC |
06-25-2019, 03:39 PM | #18 |
Rep 57
not a tow hook bracket but this would work and what I am considering as I see no other viable options. If anyone else has any idea on how to solve this dilemma the info would be highly appreciated.
https://bigmikesperformanceparts.com...ct-description |
06-25-2019, 03:41 PM | #19 |
Rep 57
06-30-2019, 10:50 AM | #20 |
Rep 3
anonymous image hosting Figured it out , ended up having to go with a Sly Bracket , Folded the license plate as well to reduce the width on it. https://www.slybrackets.com/ Tow hook mounted brackets will not work if you have PDC. Last edited by Prose1; 06-30-2019 at 10:54 AM.. Reason: Image wasn’t posting. |
Shrapnel1.50 |
07-01-2019, 02:57 AM | #21 |
E36, E46, E90, E92, F32
97
Rep 368
07-08-2019, 08:15 PM | #22 | |
Rep 2,290
Tags |
license plates, towhook |
