break in period
06-26-2005, 05:17 PM | #1 |
330 Sport, Comfort, Winter, Navi, Carbon Fiber Lip, Sparkling Graphite, Beige Leather, V710
23
Rep 155
Drives: BMW E90 330 sport
break in period
I am about to take delivery of my E90 and want to make sure to break the engine in right. Does anyone have advice on which guidlines to follow?
06-26-2005, 05:18 PM | #2 |
Rep 649
Drives: 2006 BMW 325i
Please do a search. There are a lot of posts on this topic with no real definitive answer.
06-26-2005, 05:34 PM | #6 |
Rep 666
Safest would be just to follow BMW's recommendation (will be in the manual). Here's another thread on it
http://www.e90post.com/forums/showth...ighlight=break |
06-26-2005, 06:49 PM | #7 | |
Rep 279
06-26-2005, 06:59 PM | #8 |
Absolute0
169
Rep 5,078
There's no such thing as the engine already broken in. Most people don't even have a clue what it is. The thing with breaking the engine in is that engine parts are new and that they are not 100% accurate. The break in period is to allow the parts to smooth out uneven parts. The burnt smell your car has in the first few months are from breaking in....just give it 1500-3000 miles to allow your engine to break in. All engines goes through this but if you ignore it, it won't do much of a damage as well (not going to explode or anything)
To procede or not to procede......
06-26-2005, 08:16 PM | #9 |
Administrator
6746
Rep 4,201
the factory runs engines for a bit before they release the car, so thats what alot of people mean by the car is already broken in by the factory. With modern engines built by machines with very high tolerances, I dont think breaking in an engine is an issue anymore, they essentialy are pre-broken in between the high engineering standards and the factory running the engines first.
But if its a concern to you, i would do it just for the piece of mind that comes with it, drive it under 4500rpm for 1000miles. One thing that always concerned me tho, were the metal shavings from the factory inside the cylinder. They do clean the engines but there may be a little residdue left over from the drillings so I like to get the oil changed after the first 1000 miles to make sure there is no chance of any shavings in the engine. but this is only my own superstition |
06-26-2005, 08:34 PM | #10 |
Rep 152
Here is what the manual says:
Break-in period
Moving parts need breaking-in time to adjust to each other. Please follow the instructions below in order to achieve the optimal service life and economy of operation for your vehicle. Engine and differential Up to 1,250 miles/2,000 km: Attempt to vary both engine and vehicle speeds, but refrain from exceeding an engine speed of 4,500 rpm or a driving speed of 100 mph or 160 km/h. Always obey all official speed limits. Avoid full-throttle operation and use of the transmission's kick-down mode. Once you have driven 1,250 miles/2,000 km, the engine and vehicle speeds can be gradually increased. Tires Due to technical factors associated with their manufacture, tires do not achieve their full traction potential until after an initial break-in period. Therefore, drive reservedly during the first 200 miles/300 km. Brake system Brakes require an initial break-in period of approx. 300 miles/500 km to achieve optimized contact and wear patterns between brake pads and rotors. Drive with caution during this breakin period. Clutch The function of the clutch reaches its optimal level only after a distance driven of approx. 300 miles/500 km. During this break-in period, engage the clutch gently. |
