06-20-2019, 12:41 PM | #1 |
Rep 22
HEEELP: Retrofitted LED headlights DRL - Light fault + flashes
So, i fitted the LED headlights DRL from FK-shop.de (https://www.fk-shop.de/en/Tuning/Lig...FSBM17023.html) and they look fantastic.
BUT, when i'm driving (or just holding still with the lights on), now and then an fault message for the lights comes into the display with a gong. And at the same time i can see my headlights flashing. It seems like the rings are getting too much power for a split second, and therefore they flash and the fault happens. Both the headlights does it at the same time. I've already coded LED and removed the hot- and cold checks. I've managed to record 4 episodes in the garage, where this happens. You can see it here: Have anyone seen this before? And can i do something to fix it, or is it a fault in the headlights ? |
