07-02-2019, 02:54 PM | #1 |
Rep 86
Touch Up Paint Spray??
Has anyone use a touchup spray paint? Looking for an alpine white 300 spray paint to do some touchup. I have a scratch (not metal deep) on my rear bumper but I believe is too large for touchup paint. I think a spray would be better.
Let me know if you have any experience with certain brands and if the color matched with the paint (or close enuff). I found some on amazon but it has no reviews. Thank you. |
07-02-2019, 04:13 PM | #2 |
Rep 16,151
If you're going to spray over a large area you need to do both color and clear coats. I get my paint from www.automotivetouchup.com, where you can also view how to do it tutorials.
acr12714.50 |
07-02-2019, 04:35 PM | #3 | |
Rep 86
Im not spray painting the whole bumper and I did plan to spray a clear coat on it also. TBH, I sanded down the scratch and tried using touchup paint but it just looks outta place because the scratch is too big so it looks like a blob there (even after sanding it down), I'm going to resand it down again and use spray paint this time. |
07-02-2019, 05:23 PM | #4 |
Rep 16,151
Hit it with a few coats of color to fill the scratch, wet sanding in between to remove the fresh paint from the area surrounding the scratch. When it's filled hit it with a couple more feathered color coats to blend it into the original paint, then a few coats of clear before doing a final rub out. Rub out is is much easier if you wet sand it dull with 3M Trizact 3000 grit before using compound.
07-02-2019, 05:37 PM | #5 | |
Rep 86
07-02-2019, 08:41 PM | #6 | |
Rep 10,473
07-02-2019, 09:29 PM | #7 |
Rep 16,151
After wet sanding with 3000 grit polish the area with high cut rubbing compound, low cut rubbing compound and finally polish to restore a factory finish. You need an electric buffer for large areas, but a small area can be done by hand. Beginners are best off doing it by hand anyway, a buffer can rub right through the paint, so you have to do it all again. The most difficult part about power buffing is learning how little pressure to use.
