Amp Power Terminal Options
View Poll Results: Which terminal | |||
Green | 3 | 100.00% | |
Blue | 0 | 0% | |
Purple | 0 | 0% | |
These are all wrong! | 0 | 0% | |
Voters: 3. You may not vote on this poll |
07-05-2019, 12:21 PM | #1 |
Rep 19
Hi all I keep reading conflicting opinions from older posts where to connect the amp to on the battery.
I’d like some updated/fresh opinions please (I’ll of course be using an inline fuse) I’ve attached a picture, As far as I can tell I have 3 options: Green: starter motor/alternator terminal (this one seems moderately popular) Blue: I’m not sure which this one is. Anyone know? Purple: Distribution box terminal (this terminal feeds the junction box) . (Also popular) I believe this one cuts out if a crash is detected. I’ve read people not connecting amps here talking about it potentially making the car cut out. Is there any truth in this? Perhaps they mean if the amp draws too much power it might blow the distribution box or battery safety terminal or something??? I should mention my amp only requires a 20A fuse, so that’s what I’m using in-line about 15cm (6 inches) from where I’m connecting to the battery. (Negative will be at wheel arch ground point about a foot from the amp) Thanks for any advice! Last edited by mattdc; 07-05-2019 at 12:38 PM.. |
07-05-2019, 12:47 PM | #2 |
Rep 13,122
Use and eyelet connector attached to the clamp screw on the positive
clamp lug. Mine has been connected like this for years I also go directly to the same lug on the negitive side for ground. Or you buy a connector that plugs into one of the empty slots on the battery distribution block as long as its populated with a fusible link blade. Battery dist block housing: 61136925176 (single) Battery dist block housing: 61136925166 (double) Battery dist block housing pins: 61136920092 connectors http://www.e90post.com/forums/showpo...9&postcount=19 http://www.e90post.com/forums/showth...ower+Connector connectors1 http://www.e90post.com/forums/showpo...9&postcount=19 Technicpnp.com use to make a power kit for this. I think it comes with some of there harness kits. It is advised to use one of these cause it means no hacking on the OEM wire harness. By the way there is a whole e9x stereo sub forum here http://www.e90post.com/forums/forumdisplay.php?f=27 https://www.e90post.com/forums/showthread.php?t=641323 electical e90 pdf http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja http://www.google.com/url?sa=t&rct=j...85464276,d.cGU http://www.google.com/url?sa=t&rct=j...85464276,d.cGU Last edited by ctuna; 07-05-2019 at 01:24 PM.. |
07-05-2019, 02:32 PM | #3 |
Rep 1,815
None of your circled choices. Under the tie down strap there is a little blue dot that you can go to bmw for the connector and just plug it in. Like mentioned by ctuna.
Third pic in the below post. https://www.e90post.com/forums/showthread.php?t=730390
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
07-05-2019, 03:35 PM | #4 |
Rep 19
Hi thanks for replying. The socket with the blue dot you mention already has something plugged into it, you can just see this in my photo. There are some others free though. But how do I know what the ratings are of these connections?
I’m reluctant to use these connections as they are fused, correct? And if the amp blows it I have to replace the whole distribution box don’t I? |
07-05-2019, 04:38 PM | #5 |
Rep 13,122
Yes but there are multiple sockets and any one can be used
as long as it is populated with a fusible link. Unless you have every option possible there are bound to be some empty sockets. And at 20 amps most of them should be usable. There is a picture of the fusible link strip somewhere on the web with the printed values of each link. A few people have blown out a link which means you have to buy a new link strip. (they are 30 to 40 bucks US)They blew it out because they had bad grounds or something else wrong with there wiring . But there is no risk if you choose to do it the other way(off the battery clamp lug tightening bolt). I believe the purple connection is also part of the fusible link. Read the first electrical pdf it shows the fusible link strip. Last edited by ctuna; 07-05-2019 at 04:46 PM.. |
