Coolant Bleed Procedure Question
07-10-2019, 06:29 PM | #1 |
Rep 63
Hi all,
Last week I was driving out of town and got the warning of my car overheating so I pulled over and learned the expansion tank burst and leaked coolant all over the engine. I had the car towed back to my house for a DIY on replacing the tank. I’ve replaced the tank and topped off the coolant. Im now trying to bleed the coolant lines but the fan keeps kicking on and cycling off the water pump. Im assuming the fan is kicking on because the last time the car was running, it was flashing an overheating signal. Any idea how to get the fan to stop turning on and interrupting the bleed process? |
07-10-2019, 06:57 PM | #2 | |
Rep 2,189
The fan running is usually a sign of this. Time to pull codes to verify. |
07-10-2019, 07:03 PM | #3 | |
Rep 1,753
Make sure the car is cool when ur doing the bleeding. Does the pump run when you start the bleeding procedure ? If the fan is still kicking in even with the car off ( which doesnt make any sense) but if it does than ur pump could be bad but you should be pulling codes. Agree with above post. |
07-10-2019, 07:10 PM | #4 |
Rep 63
I haven’t started the car since it overheated last week. The pump kicks on immediately when starting the bleed procedure. It runs for a minute or so, then the fan kicks on. It’s hard to tell if the pump cycles off immediately once the fan kicks on since the fan is so much louder. I don’t have anything to read codes but the car currently only signals a maintenance reminder to change my brake fluid (which I knew).
07-11-2019, 07:27 AM | #5 | |
Rep 63
07-11-2019, 07:47 AM | #6 |
Art Collector
2427
Rep 3,450
No. You’ll need to pull codes. It might not have outright failed yet, but if it’s on its way out, there is often something stored (electrical coolant pump speed deviation code, for example).
07-11-2019, 08:30 AM | #7 | |
Rep 85
I usually set the cap on the tank to avoid splashing.
2007 530I, 2007 328xiT
2003 325XI (gone) 2004 530I (gone) 2001 530I (gone) BMW CCA Member 15+ Years |
07-11-2019, 08:32 AM | #8 |
Rep 63
In the interim, just to get the car running, could I disconnect the battery to erase any engine overheating code so that I could perform the bleed procedure? The radiator fan keeps disrupting the bleed procedure.
07-11-2019, 08:34 AM | #9 | |
Rep 18,800
If you find any WP codes, then the pump is going bad. |
07-11-2019, 12:19 PM | #10 | |
Art Collector
2427
Rep 3,450
A scan tool or cable is the single best investment you can make for these cars. Since time is of the essence for you, I’d suggest trying to find a cheap cable on Amazon, get it shipped as fast as possible, and read/reset codes tomorrow. Sorry if you’ve already mentioned this, but are you following the bleed procedure to the letter?
07-11-2019, 12:40 PM | #11 | |
Rep 63
As far as I know I’m following it step by step, I did it 6 months ago and it worked. I closed off the bleed valve and screwed on the cap. I went in to the car, put the key in and pushed the start button twice to bring up the accessories. I turned the heat to 84 and on the lowest fan setting. Then I held the gas down for 10-12 seconds until the pump kicked on. It starts flushing the coolant like normal till the radiator fan kicks on. I’m going to try turning the accessories on without running the bleed procedure to see if the fan kicks on. I have some time to play with it. Thanks for your help so far in this! |
07-11-2019, 02:05 PM | #12 | |
Art Collector
2427
Rep 3,450
If you're tech savvy you'll be fine. INPA (which I use) doesn't have the greatest interface and is kind of buggy, but it gets the job done. ISTA is better from what I hear, but I haven't used it. Finally, if all you're looking to do is read or clear codes, Dr. Gini, which is included in the BimmerGeeks BMW software package (free), is really easy to use.
07-11-2019, 04:12 PM | #13 | |
Rep 1,579
https://www.bimmerfest.com/forums/sh....php?t=1023698 |
07-15-2019, 01:34 PM | #14 | |
Rep 63
DME - 2 errors stored, 377A and 3792. After a quick search it appears both codes are related to the cooling system. Is there a chance they're caused by the expansion tank bursting and leaking fluid, causing the overheat? Is it possible to clear the codes and try the bleed procedure? I'm just not convinced the water pump is 100% gone since it kicks on at the beginning of the bleed. I just want to be able to drive the car to a repair facility to replace the water pump since it sounds like it's going bad anyway. |
07-18-2019, 01:19 PM | #15 |
Rep 63
So I couldn't get the bleed procedure to complete without the radiator fan kicking on, so I pulled the fuse on the fan. Once I pulled the fuse on the fan and initiated the bleed procedure, the water pump kicked on and ran without a hiccup. The only concern is the pump ran for 15-16 minutes before I turned it off. Any idea why the pump would run so long?
07-22-2019, 11:08 AM | #16 |
Rep 27
Crazy because the exact same thing i am experiencing now. Was driving then i started smelling coolant. Pulled over saw steam coming from hood. Weird because my hood for some reason wasnt closed all the way.
Saw coolant all over engine and hood. Checked hoses and didnt see anything ruptured but heard coolant boiling in ofh. Poured a half a gallon in tank and tried to bleed. Pump started then fan came on. Everytime i try same thing. Saw all the coolant pooling on underbody tray. Guessing its the radiator and wondering if i should spend the money on a pump and thermo as well. Hope you get it figured out im in the same boat. No cooling system codes found when checked with mhd. Need to use INPA today. |
07-22-2019, 11:56 AM | #17 | |
Art Collector
2427
Rep 3,450
07-22-2019, 12:12 PM | #18 | ||
Rep 4,088
From your description of the events (Expansion Tank Rupture causing overheat), it is POSSIBLE that fragments of tank plastic jammed the pump, at least momentarily. INPA tells you whether a particular Fault is "Currently Present" or NOT. You have to connect to the DME and read Fault Details (NOT just use Functional Jobs to read code numbers) to do that. It COULD be (particularly if you hear pump running when doing "Bleed" procedure) that you could CLEAR both those codes and that would fix the problem. HOWEVER, before you do that, you want to read and SAVE ALL related Fault Code Details and Freeze Frame Data now saved in the DME, and also do tests (Activation) of your Coolant Pump. Don't just throw parts at it. You have INPA and if used properly, you can diagnose the issue as well or better than a shop (since it's YOUR car and you can take time a shop can't). Apparently from the Code numbers you posted, you have a 2011 or later 335i/xi with N55 Engine and "mevd17xx" DME? Here are the Fault Code Definitions from "BMW Fault Code Lookup": 377A | Engine cooling system: coolant pump switched off due to blockage | mevd17kw 3792 | Engine cooling system: Coolant pump speed outside of tolerance | mevd17kw I would suggest using INPA, F6 Activations > Coolant Pump (Wasserpumpe) to monitor SetSpeed vs. Actual Speed (Pump Speed Deviation). The Fault Codes suggest the pump impeller WAS jammed and the motor COULD NOT turn, causing excessive current draw/heat, and causing the DME to cease activation of the Pump. Those conditions, and the Faults described by the codes may NOT BE PRESENT at this time. INPA will tell you "Fehler momentan nicht vorhanden" which means THE FAULT IS NOT CURRENTLY PRESENT if the pump was momentarily jammed, but operating properly NOW. Many people would just replace the pump based upon those two codes, but I would suggest using INPA to make sure, BEFORE replacing. Even if (1) Faults described by the Codes ARE currently present, and return after Clearing, and (2) the Activation test confirms Pump will NOT run, you at least have learned something about use of INPA which will be valuable in the future. Please let us know what you find, George Last edited by gbalthrop; 07-22-2019 at 12:36 PM.. |
08-11-2019, 10:12 AM | #19 | |
Rep 63
So I thought the car was fixed for a couple weeks, it ran fine with no overheating issues around town. Last week though I headed out on a 3 hr trip and halfway in, the car overheated. I nursed the car another 30-40 miles over the course of 2 hours, then just elected to have it towed to my destination. I don't have a computer to read the codes now (I'm 2.5 hrs from the car now), but am having a water pump/thermostat installed tomorrow. I'm just not sure why the car operates fine around town and overheats after 1.5 hour drive. This time around I can tell it's not leaking coolant. I could turn on the heat in the car and drive 40-50mph and the car wouldn't overheat, so it would seem the thermostat is functioning properly. You're correct, the car is a 2011 with the N55. I'm hoping the new thermostat/waterpump fix the issue, but the car has almost 90k miles on the original waterpump, so I'd likely need/want to replace it soon anyhow. If you're able to help me better understand INPA, or if there's a forum that explains it, that would be great. I searched and didn't see anything, but I could've just missed it too. |
