E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > BMW e90 325i 2006 Rear Window Does't Work
Reply
      07-11-2019, 06:15 PM   #1
mider111
Drives: BMW E90 325i 2006
I was driving my car when I heard a weird noise from the right rear window. I tried opening and closing it and heard a breaking sound. Now my window is just loose. Doesn't go up, doesn't go down. I can move it up and down manually with my hands. When I drive it keeps coming down but I put a suction cup on it so it is good for now. Called the local BMW dealership and they want $550 for it. Sounds insane, I know.
My question is do you think it is the regulator or the motor that needs to be replaced? I found some videos on how to replace them and the parts I need but I am not sure which one it is.
      07-11-2019, 06:28 PM   #2
alfazrus
Drives: 2006 e90 330i
Most likely the regulator. Common.
      07-11-2019, 06:59 PM   #3
arveeezy
Drives: 2006 330i E90 N52
Exact thing happened to me 3 months ago. Its very easy to replacement if you have spare time to do it. I did it on my own and bought the replacement from amazon.
The snap you heard was probably and most likely the cable, and it finally snapped.
here is the part:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
watch this video, its very easy to follow:
Good Luck!
      07-11-2019, 07:02 PM   #4
bob.g
Drives: 2006 325xi
yeah prob the regulator. its easy enough to replace. i bought a cheaper 25$ ebay version when mine busted a few years ago. It doesn't roll up or down as fast, but it works ok. Just make sure you follow the steps to reset it once your done otherwise it wont roll up all the way, or it rolls up and back down, i forget, but it wont work properly.
      07-11-2019, 10:26 PM   #5
mider111
How do you reset it? And yeah my rear left window when it goes all the way up it goes down again. Have to reset it as well.
      07-12-2019, 08:25 AM   #6
bob.g
Drives: 2006 325xi
This guy explains how to reset it towards the end end of the install:
Reply
Tags
broken, motor, rear, regulator, window
e90post
