New and need help BAD Pls...
08-13-2008, 10:03 AM | #1 |
Rep 49
My wife owns a E90 320i 2005 reg sept, we bought this car 3 months ago and had some problems with it. As the car is under manufactures warranty we booked the car into our local garage to have these rectified. Our life since this day has been stressfull.
I will highlight the problem first as i dont want to bore you to death. We cannot control the tempreture of the airflow it just spills out so hot air all of the time. this only started happening since it visited a BMW dealer.Even with the airflow turned off its still to hot to drive the car. Brief history.... We bought the car and she has enjoyed driving it, there was a couple of issues and one being that you couldnt control the airflow in the car it changed direction with no control. BUT you could conrol the tempreture. After 1 day at our local dealer we were told that it needed to come back in a week as they needed to order parts. 1 week later dropped the car back and got a loan car. this was meant to be fixed in 2 days. 1 week later we were told that the car has had a heater control unit fitted after it was new and this was the wrong part. I accepted this then they tried to give me a £1500 bill for labour. when booking the car in i asked them to inform me of any work that required payment and i never had a call. After a few telephone calls they asked me to collect my car and i didnt pay the bill. When my wife collected the car all air coming through the car was so hot the car its un drivable. even turned off its still so hot. They diagnosed that it needed a new and correct heater control unit plus recodeing. When i asked them to return the car to its original state i was told this was imossible and we would need to buy the parts needed and recode the car. After our bad situation with this dealer we booked the car into a dealer near her work and asked them to fit the new unit and recode the car. This was done and it never sorted the problem, although the air blows consistantly out of one area you cannot change the direction and its soo hot. The second bmw dealer suggested dropping the car off for a week and they will investigate. I stated there labour cost over £100 per hour and i could end up with a bill of £6000 before we establish even if this problem was covered by the warranty and if not i would have to pay the bill. After all this i of course would love to sort the problems but the main reason the car cannot really be driven is the air so hot... we felt that the dealer did something to the car due to the situation we had, but of course this is speculation. I do have a friend who works for a local independant garage who put the car on there code reader and it came up with 9 faults all to do with the heater system. One of the faults was a faulty tempreture sensor that had a -21 reading. He thought that maybe this is the reason why hot air was constant. Any input from you guys would be greatly appreciated..... |
08-13-2008, 10:16 AM | #2 |
Rep 8,095
If this was a main BMW dealer they should be shot. Sounds like item 4 here:
http://www.realoem.com/bmw/showparts...54&hg=64&fg=40 of which there are 2, internal and external, and the control unit aggregates the difference. If the temperature sensor is faulty and believes the interior temperature to be -21 then it will 'correctly' blow hot air to compensate. How the dealer has not found this is unbelieveable. If it is this sensor it would also explain why fitting a new control unit fixed nothing. This sensor is only a tenner! It may not be this part but for them not to know and try fixing by random substitution is ridiculous. If it's under manufacturers warranty you should pay nothing.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
08-13-2008, 10:21 AM | #3 |
Rep 49
thanks
Hi Ian,
We have had big problems with BMW, anyway the part looks like part 4 on the link you sent me. How do we get to this part. is it behind the dash? The part is very cheap so if i can have this changed at a reasonable cost it makes sense to try this. Thanks for your quick reply |
08-13-2008, 10:23 AM | #5 |
Rep 8,095
I've never changed it in all honesty, but yes it is behind the dash and probably a bit of a pain in arse to change. The sensors (known as hedgehogs) needed to be regularly changed on the e46.
Your friend could probably change it for you(?)
Ian
08-13-2008, 10:25 AM | #7 |
Rep 9,915
Drives: VW T5
I would be talking to the boss of the garage you brought it from. Demand it is fixed immediately or you will be seeking legal advice. If they don't then you have good grounds to reject the car.
Have you spoken to BMW UK? |
08-13-2008, 10:26 AM | #8 |
Rep 8,095
Looking at the drawing I posted the two outlets at the top are the two in the centre flat part of your dash, so the whole assembly is behind the dash. They may be accessible from the bulkhead in the engine bay - I've never changed them on an E9x
Ian
08-13-2008, 10:26 AM | #9 |
Rep 49
Hi MOB, i was thinking this also.. the way the warranty works is they work to find the problem. then if they deem it to be a warranty claim its honured, if not you pay the bill. So far bmw have had the car 3 times total 11 days and we have still not sorted the problem. Infact we have taken one step back
08-13-2008, 10:28 AM | #10 |
Rep 8,095
I don't know where in the UK you are but I'd go to another dealer and ask them to change the two sensors specifically. Either way, it should be fixed under warranty - it is faulty so I can't see how it cannot be a warranty claim.
Ian
08-13-2008, 10:29 AM | #11 |
Rep 1,413
08-13-2008, 10:29 AM | #12 |
Rep 49
Yes i spoke with customer services BMW today and they advised me that until the problems was diagnosed correctly they couldnt comment if it was a warranty issue. After 2 dealers and 11 days its a bit stressfull, also we bought the car private so cannot go back to any dealer
08-13-2008, 10:31 AM | #13 |
Rep 8,095
It is a warranty issue - it can't not be. Find a different dealer if possible, tell them some muppets have changed the control unit but an independent (not authorised to do warranty work) diagnosed the sensor. You have no faith in the original dealer so could they change the sensors for you under warranty?
Dealers love it when you slag off one of the others and like to prove they're better. Sometimes...
Ian
08-13-2008, 10:40 AM | #15 |
Rep 8,095
As shown on the diagram, they are both within the A/C unit. I don't think one is easier to get to than the other, but hopefully you may hear from someone who as actually changed one or other.
Ian
08-13-2008, 11:37 AM | #17 |
Rep 5,984
Have a look at this pic...
Can you see the long metal thing in the vent on the left? I think that is your cabin temp sensor. Well it is the temp sensor that measures the air coming from the vent and reggulates it, the temp sensor is in the climate control unit I believe. Also, pop the climate out, there are two cables in teh back of it, if one of these is not right then you only get hot air, these can come out when people install/remove car kits. So check that. Check the connectors on the back of the climate first before doing anything else. To get to the thermostat in the vent you pop the interior trim off first, the long bit of wood or aluminium, start with a blunt knife behind it on the passenger side end, slowly lever it up, it is on pins, you cna then slowly pull it away from the dash. Once off you can then remove the air vents and you can see the thermometer. |
08-13-2008, 11:50 AM | #18 |
Rep 5,984
I think there is another one that regulates temperature that you can get to by removing the trim under the steering wheel.
Have a look in the realoem link about, part 8. |
08-13-2008, 12:14 PM | #21 | |
Rep 2,333
http://www.realoem.com/bmw/showparts...54&hg=64&fg=40 and look at part number 8... hth
Current: F13 640i MSport, e85 Z4 3.0i
Previous - Alpina D3 BiTurbo E90 LCI Manual, 320d M Sport E92 Auto, 330i M Sport E92 courtesy of BMW UK....320i M Sport E92 Auto, 320d SE E90 Manual. |
