New rear rotors and pads aren't grabbing
07-17-2019, 11:40 AM | #1 |
Rep 66
So kind of a strange question. I've installed new rotors and pads all around. The fronts are working just fine however the rear aren't grabbing they still look brand newish after 2000k miles. No warning lights on dash and they were installed correctly the sliders move freely and the caliper piston slid back smooth with no efforts. Kind of scratch my head here. 2007 E93 vert. RWD. Do the back pads only work when hand brake is applied? I do have inner shoes on the car.
Thanks Guys. |
07-17-2019, 12:08 PM | #2 |
Art Collector
2427
Rep 3,450
As reliable as the N52 is, I'm assuming your rear brakes don't have two million miles on them (2000 x 1000...). Are you saying they still look brand new after 2000 miles; roughly 3000 kilometers?
They're barely used; they should look new. Braking systems in most passenger cars are front-biased, meaning the rear brakes do less of the work. They tend to wear slower. Does brake performance feel off? If not, then don't worry about it. You would know if your rear brakes aren't functioning, unless you're not familiar with how brakes should feel. It's not clear based on your post whether there's actually a braking issue, or whether you're simply curious why your rear pads still look new. Please clarify if the above doesn't answer your question. The shoes are for the handbrake only.
07-17-2019, 12:16 PM | #3 |
Rep 66
Hey e90. Thanks for the get back. What I was trying to say is that when after 3000 kms there isn't any wear marks on the rotors in the rear. While I get that passenger done use to much of the rear I would just assume after 3k there would be some indication it's all. Braking system is solid. I was more curious then cautious.
07-17-2019, 01:06 PM | #4 |
Rep 148
If the rear was not working at all, the rotors would actually look dirty and somewhat rusted. If the rotors are clean and shinny, they are working to some extent.
07-17-2019, 02:15 PM | #5 |
Rep 2,607
Drives: 06 330i E90, 18 530xe G30
Any chance when you had did the pads you completely removed both calipers? Only reason I ask is it is possible to install the calipers on the wrong side but have them bolt up and look right. Problem is when you come to bleed them the bleed nipple is pointing down and air gets trapped in them essentially making them useless, which describes what you're seeing.
Ask me how I found this out...... |
07-17-2019, 05:41 PM | #7 |
Rep 66
silly question but do I have to bleed the lines after changing rotors and pads>? i've never had to do this on other cars but with bmw you never know. thanks
07-17-2019, 05:43 PM | #8 | ||
Rep 66
07-17-2019, 06:36 PM | #9 |
Rep 148
Just changing rotors and pads should not introduce air into the system requiring bleeding. However, I change the fluid and bleed anyways when I install new pads and rotors. Sounds like you have checked everything else. For peace of mind, change your brake fluid and bleed. See if there is any improvement. Also, are you getting brake dust on your rear wheels?
07-17-2019, 09:04 PM | #11 | |
Rep 66
07-17-2019, 09:06 PM | #12 |
Rep 66
07-18-2019, 07:11 AM | #13 |
Rep 1,753
Brand new rotors are covered in a film and look usually matte in color. When u start using them they look more shiny on the area where the pad touches. This change in color happens like almost immediately. Did u notice this change or they still look like factory ?
07-18-2019, 10:09 AM | #14 |
Rep 66
For the back rotors I didn't get them Zin coated they see standard rotors with ceramic pads. The rotors don't have a mat coating fronts yes backs no. But yes they do looks like they are still new maybe it's to early to tell. I know with the front they are already worn in. Strange, but braking is solid. Maybe when I have some time I'll take them apart again and see whats up.
