07-20-2019, 07:31 AM | #1 |
Rep 33
KW street comfort spring binding
Finally figured out what is causing my horrible noise. The spring coils are binding (lower two). How do I fix this?
07-21-2019, 11:36 AM | #2 |
Rep 1,523
you're not the first one. someone else had the same issue. look at all the coils compressed, there's hardly any room for more compression. those springs are too soft for the car.
07-21-2019, 02:28 PM | #3 |
Rep 10,304
Did you install the coilovers yourself or was it the installation done by a shop?
Thanks for sharing the picture. It appears the spring pre-load is excessive. |
08-23-2019, 06:04 AM | #4 | |
Rep 590
As I only had them on for 2 weeks and had them professionally installed at the dealer, KW replaced the front springs with stiffer springs. I knew of two other F31 wagon owners who also had to have springs replaced. Good luck.
2018 MG F80 M3 ZCP | BBS LM?s | Michelin Pilot 4s | BMW HAS Coil Overs | Stek PPF | DINAN CF Intakes | IND Engine cover | Akrapovic Evolution Exhaust |
2018 Champaign Quartz F31 Sports Wagon | BMW 624 wheels | KW Street Coil Overs | DINAN Stage 1 v2.0 | Soul Performance Muffler delete |
09-11-2019, 12:37 PM | #5 | |
Rep 891
Lowering the collar and removing the spacer will reduce binding, if the height is unsatisfactory you'll need a stiffer spring. It must be riding and handling terribly with that much coil bind.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
