07-22-2019, 05:29 PM | #1 |
Rep 100
Lowered 2016 F36 RWD on H&R Sport Springs but Not Happy with Drop
The car has the M-Sport Package (non-adaptive) suspension. I figured I'd go with H&R Sport Springs to close the wheel gap. I did not want the car slammed as I have dealt with that in my past and it's fun and all but it can get annoying after a few broken lips and pot holes from hell.
To make a long story short, I'm not happy with the drop. I feel like my rear left side is sitting higher than my rear right side and it's as if there was no change in ride height. The wheel gap is still there (see pics). I'm almost certain I installed the springs correctly. I say this because the rears were nothing compared to the front in terms of time and energy spent with the installation. It was pretty straight forward. Btw, the front did drop and I'm happy with it. Has this happened to anyone else? I've read on here that the springs will settle after a bit but I am not seeing any signs of that (yet). I included pics. Maybe I'm overthinking? You tell me. |
07-22-2019, 05:54 PM | #3 |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
Have you had the car aligned? IME I often see that after changing springs it drops a slight bit more after alignment.
You really need to measure before/after hub to fender distances too to really gauge lowering.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
07-22-2019, 05:58 PM | #4 |
Rep 100
Not yet. I read about that too. I feel like another .5 inches is needed to close the wheel gap. Maybe slightly more than that.
07-22-2019, 07:07 PM | #5 |
Rep 10,304
Based on pictures, I think the wheel gap isn't as onerous.
It's not coincidental that there is another parallel thread started by 340girl discussing the same issue: whether lowering springs will close the wheel gap. Lowering springs have one "setting" without any tuning mechanisms: what the springs have been designed to offer plus any post installation settling. Will it be satisfactory? Only you can decide. For precise suspension height adjustment, coilovers remain the optimal choice although at a higher price. |
07-22-2019, 11:45 PM | #6 |
Rep 100
I completely agree with what you're saying about coilovers being the optimal choice for height adjustments. I knew that before I bought the springs. In fact, I had coils on my previous car and enjoyed them for a while.
I based my decision on these sport springs because of the many reviews and pics with similar cars on these exact springs. I saw the approximate height that the sport springs should lower the car to. Of course no two cars are the same but there's a range that I was expecting it to drop to. I wasn't expecting a slammed or tucked look either. That's definitely not what I was going for. What I also wasn't expecting were my results, so I'm somewhat confused that it turned out this way. I'm hoping they settle a bit more or else I'll just have to get rid of them and go with coilovers. For now, if anyone has seen an uneven side and has somehow fixed it then then please point me in the right direction. I'd greatly appreciate it. |
cfm56d7b5919.50 |
07-23-2019, 01:36 PM | #7 | |
Rep 7
I think yours looks good! |
DeeM5527.50 |
07-25-2019, 10:16 AM | #8 |
Rep 7
As promised here are the pics - completely stock '18 340i xDrive Msport package
Tape measure location is not 100% accurate due to where I could place the end of the tape measure but you get the point - it appears that the front has more gap than the rear. pic 2 is front pic 3 is rear |
07-25-2019, 12:31 PM | #9 |
Cheapskate
4457
Rep 4,995
Sport springs will reduce the gap but not eliminate it. I still had a gap even with super sport springs. So I finally sucked it up and bought coilovers to get the ride height I wanted.
It's also common for the ride height to be slightly different from left to right due to the battery location, gas tank, etc. |
07-27-2019, 04:36 PM | #10 |
Rep 24
It seems to be pretty common to find people complaining about their wheel gap with Sport Springs. What you have to realize is, disregarding that they're not coilovers, they're only a 1" drop at most. If you want to make a wheel gap almost unnoticeable until you can afford coilovers ( what I'm gonna be doing ) get Super Sport Springs, they should have about double the drop as the Sport
