08-09-2019, 10:28 AM | #1 |
Rep 1,290
Help installing rear difuser
I have the exact same issue with TWO rear diffusers I bought (2 different sellers). The right top side just below the reflector keeps popping out and is not flushed with reflector. I press it in, I hear the tab click and as soon as I let go, it pops out.
I'm thinking I might need to trim or shave the back of the diffuser a little to help settle and become flush with the reflector. Has anyone else had this issue and how did you solve it? I like the diffuser and don't want to return it AGAIN. And since I'm having the exact same issue I'm starting to think my rear bumper is not even on both sides.
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
08-09-2019, 11:04 AM | #2 |
Rep 2,962
Are there tabs on each end? Your best bet is to take the bumper off, push the tabs in and put a bolt/screw/nut/whatever to hold it tight in place.
2015 335i Msport/6 JB4/EWG/E30/VRSF DP/ER CP/ VRSF Race Exhaust/ Injen Intake/Verde Axis 19x8.5/9.5 245/35/275/30 Conti Extreme CS/ H&R Sports / Motorsport Hardware Stud Conversion
McLaren720s1479.50 |
08-09-2019, 11:13 AM | #3 | |
Rep 5,400
I know that I watched the installation video on YouTube from Kies Motorsports where I bought the diffuser. I'd suggest removing the reflectors and wait to install them after the diffuser is in place. Try changing the order that you are pushing in connections: left to right, right to left, center out, outside in, etc. Where it's popping out there may just be an edge where two pieces of plastic come together where one is supposed to go on top of the other and they are accidentally reversed. I wouldn't start thinking that you need to trim, cut or sand anything. One of the things above will probably solve it. Good luck! |
08-09-2019, 12:06 PM | #4 | |
Rep 1,290
08-09-2019, 12:10 PM | #5 |
A family of bimmers
2757
Rep 7,743
I had a similar problem with my f30 and removing the reflectors made it that much easier. it also give you a chance to wrap the reflectors in gloss black vinyl to match.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
McLaren720s1479.50 johnung4540.00 |
08-09-2019, 02:25 PM | #6 |
Rep 227
Drives: G81 M3T / X5 F15 30d
I had the same problem, I think it is because of the gloss paint, the paint seems to get in the way on the tabs. My problem was also on the right. In the end not entirely sure how but I managed to get it to stay. Fingers crossed, but has done a few thousand miles now and still there. I also removed the reflectors
Proud owner of G81 M3 Touring
08-09-2019, 08:21 PM | #8 | |
Rep 1,290
I can now confirm that it fits and looks great! After popping out the reflectors it was easy to adjust the diffuser and make it fit. Thanks to everyone who suggested that!
08-09-2019, 09:45 PM | #9 | |
Rep 5,400
