08-11-2019, 11:26 AM | #1 |
Rep 55
Climate Control Unit
I have a 2015 F30. Been seeing the climate displays but with the lettering/numbering appearing in white. Anyone know where I can get one? Attaching my current with the orange.
08-11-2019, 12:24 PM | #2 |
Rep 1,702
Drives: 2014 428i and 2018 X5
eBay.
But your car must have IHKA3 so you'd have to verify it has that. This topic has already been covered extensively in these forums, so do a search.
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
08-11-2019, 03:22 PM | #3 |
Rep 55
08-11-2019, 05:37 PM | #4 |
Rep 2,214
Try searching using "IHKA3" in the search box. You might find posts in this section:
https://f30.bimmerpost.com/forums/fo...play.php?f=426 Good luck!
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
08-11-2019, 07:55 PM | #5 | |
Rep 10,473
You need to read this entire thread to retrofit everything. https://f30.bimmerpost.com/forums/sh....php?t=1274250 |
08-12-2019, 09:24 PM | #6 | ||
Rep 55
Is that not the case? |
08-12-2019, 09:27 PM | #7 | |||
Rep 10,473
If you can switch colors on the climate control unit you have IHKA3 in your car. IHKA units do NOT have that ability. |
09-07-2019, 11:52 AM | #8 |
Great Teacher
1124
Rep 1,314
Drives: 06 e91 325ix
you have a 2015 so you should have ihka3 already, you just need to replace the control head for one that has the bicolor leds and code it.
its one of the first things i plan to do when our 2015 arrives along with the LCI panel. you need to swap back before taking the car to the dealer so dont get rid of the orange one |
09-08-2022, 03:40 PM | #9 |
Rep 8
Climate control and radio panel not powering on
I have don't no modifications on the car I checked the fuses and they are all good. When I turn my car in now the panel doesn't light but but after about 5 min it will turn on.
I also have a weird AC issue where it will work and blowCold air as long as I don't take it past 3 otherwise it blows warm but the low pressure side is high at 50-60 and I can hear it turning on and off. But if the panel turnes on the screen light will blink. The mechanic that I called said that sounded really weird and asking if it took on water and it did not. Is there anything I should Check and how do I do it? |
