08-13-2019, 10:18 AM | #1 |
Rep 7
BMW F30 EPS Thrust piece
Hi chap,
I have an issue with my driver side making a clonking sound if i go over a rough terrain or while stationary and rocking the steering back and forth. More pronounced with the engine off. I believe the previous owner had EPS issue and the vehicle was on a steering Recall and rectified by BMW. since then i have acquired the vehicle and the clonkiness. could it be the BMW did not perform a correct EPS thrust piece install? secondly can i approach BMW as they did the work previously. Also i have been reading about tightening the sealing plate on the EPS thrust piece by 1/4 turn which has solved most of the issues. Should i perform this myself or take it to BMW. Any suggestions greatly appreciated. |
08-21-2019, 11:10 AM | #2 | |
Rep 163
there's a repair kit for this issue, and a detailed repair bulletin on TIS, and its quite the process. even if you wanted to adjust that nut plate on your own, you'd have to create a tool, as buying it is no easy feat either. and BMW will not touch that nut, as there have been cases where rack failure occurs. most people end up getting a rack from a junkyard and coding it. but then again, you're never sure of the condition of that thrust piece, and how long until you have the noise issue again.
2020 X3MC
