08-16-2019, 02:03 PM | #1 |
Lurker
26
Rep 61
F30 Adaptive Suspension compatible springs/coilover?
After reading a bunch of posts and asking around, I have a question on what options I have that would be compatible with the adaptive suspension package on my 340i.
Im currently looking into just doing springs offered by dinan: https://www.dinancars.com/product/d1...?series=&mid=/ I think I read somewhere this should be fine because I would still be using stock struts/shocks. If I wanted to change to coilovers, what could I do because changing the entire setup would probably interfere with the electronic suspension? I'd appreciate any help here |
08-16-2019, 03:45 PM | #2 |
Rep 832
Drives: 2019 G01 X3
You can use any coilover setup and either use a EDC delete module (e.g. KW) or code out EDC.
08-16-2019, 11:02 PM | #5 |
Lurker
26
Rep 61
Its a 2016 with just almost 18K miles. The shocks here dont really lower the car which is the look I am going for.
08-17-2019, 03:58 PM | #6 |
Rep 787
Look at the Dinan springs + supplemental handling package. The springs lower the car a bit (and are stiffer) and the supplemental package is just a set of shorter bump stops to pair up with the lower ride height. You retain the OEM adaptive damping +shock absorbers which in your case have a lot of life remaining on them and are over 500/piece new. It's about 500 worth of parts for a pretty good good improvement in performance and appearance while retaining full OEM function (and warranty) . Coil over kits will be considerably more expensive and require an edc delete module or coding to disable the adaptive suspension or you'll have drivetrain warnings, I'm told.
YEET8226.00 |
08-19-2019, 02:29 PM | #7 | |
Rep 128
If you find utility in being able to choose between soft and firm damper settings, then keep EDC. Personally, I always drive with firm settings, so have no need for comfort mode. I have gone a passive B14 kit and coded out EDC. |
08-19-2019, 04:08 PM | #8 |
Rep 129
08-19-2019, 05:47 PM | #9 |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
You leave it attached to the strut you remove. Coding it out will make the system think it isn't there anymore and it won't look for it.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
Kefka32.50 |
08-22-2019, 08:32 AM | #10 |
Rep 411
MSS Kit is developed for stock struts (adaptable or not) liked them very much on my VW R32
https://mss.company/ |
08-22-2019, 11:30 AM | #11 | |
Rep 3,540
08-22-2019, 01:19 PM | #12 |
Rep 141
If your car is the LCI model, it should have the revised dampers. I would just go Dinan Springs + Bumpstops + Shockware and call it a day.
The passive sport dampers and the adaptive dampers sport mode are probably close enough to design one set of springs for the softer suspension. Comfort mode will suffer though.
2014 328i xDrive M-Sport EBII--M-Performance BBK/LSD/Aero--AA Signature Exhaust--Bilstein B6 DampTronic + Eibach Springs + H&R Swaybars + Millway Street Camber Plates + M3 Bump Stops + Dinan Shockware--Apex ARC-8 18x9.5et35+12mm Front Spacers w/Kumho Ecsta V730 275/35--FL-5/EC-7 18x8.5et35 w/Pilot Alpin PA4/Hakkapeliitta 10 Studded 245/45--BavSound Stage 1+Ghost Subs
08-22-2019, 01:31 PM | #13 |
Rep 3,540
This is within the realm of possibility for models whose base suspension and adaptive suspension use the same springs, however for models that have an actual "base" suspension and EDC uses springs closer to "M-sport" rates, no way.
08-23-2019, 09:28 AM | #14 |
Rep 411
Please use stock/ Koni red/ Koni Yellow / Koni FSD/ Monroe/ Bilstein / Oehlins..... all with the same springs. All of those have different characteristics.
Pretty sure the MSS would work best with the Adaptive as they provide a nice comfortable ride (but still stable/sporty) with less understeer, body roll .... and in addition the ability to adjust the height as needed (based on other reviews and my VW R32 experience with Oehlins) Will get a set in the spring time when/if I decide to buy out my M240 vert lease |
08-23-2019, 10:04 AM | #15 | |
Rep 141
When I came back to America in the fall of 2015, I had about 30k miles on the car. I don't remember having an issue with my run-flat summer tires. I know when I installed the go-flat 245/45 winter tires I added some extra bounce to the ride. Switching back to my run-flat summer tires removed that bounce. Again, most of my driving was done in comfort mode. At 49k miles I finally upgraded to Dinan Shockware, granted the dampers were probably starting to wearing out. I should/would have installed this sooner, but I was waiting for the B6's to be released. This was spring/summer of 2017. Last spring at 70k miles I switched to MP4S' and really needed new dampers, "comfort mode" was fine on smooth roads, but falling apart on a lot of bumps and undulations. "Sport mode" would fix most of these issues. I was in the mind set if I replaced my dampers, the B6's would be released the following week. At 84k miles the B6's were finally installed. At 85k I switched from Dinan to Eibach's to fix the ride height issue. Now I'm at 86.5k miles and the ride has been great, however I do wonder how it would have been if I installed there revised LCI dampers instead of the B6's. But hey, what do I know I'm not looking at dampening charts, only driving the car and reporting what I feel.
08-23-2019, 10:34 AM | #16 |
Car Hypochondriac
335
Rep 903
Drives: 2014 335i M-Sport Estoril Blue
thisismikeyb revised LCI dampers??
Edit: I had no idea this was a thing, I assumed they were the same dampers.
Power mods: VRSF IC/Catted DP - FTP CP/BP - AFE Cat-back - BM3/XHP - Dorch S2
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
08-23-2019, 10:58 AM | #17 | |
Rep 3,540
I've tested over 13 spring combos on my vehicle and have been very surprised how well frequency and critical damping calculations match with feeling. Calculations that have told me "this spring rate is where you really start to get underdamped" proved exactly that when I took that combo out on my test roads and hit successive cresting features. Most of the setups felt "fine" for daily driving (except ones where the F/R ride frequencies were about 1:1), however, the better optimized setups showed clear superiority on the track and test road.
09-15-2019, 11:18 AM | #18 | |
Rep 509
Drives: 2016 435i
Currently thinking of going Dinan + bump stops + shockwave as I feel substantial BMW specific engineering has gone into this set up. I truly love the adaptive functionality. I too drive in comfort mode most of the time. 90 miles of commuting every day so I enjoy the cush. Being completely honest I just want to get the ride height where I want it without sacrificing the current setup. A solid inch all around. |
09-15-2019, 01:14 PM | #19 | |
Rep 3,540
I'm convinced that dinan shockware and dinan springs were developed independently of each other and weren't explicitly designed to be paired together (otherwise shockware would have more than one part number). You sound like a good candidate for the DIY Rear HAS. That way you only really have to find the right spring that lowers your front the 1in.
09-15-2019, 01:47 PM | #20 | |
Rep 509
Drives: 2016 435i
I ended up going with ST Coilovers on my E92 but the EDC option that my F32 came with has muddied my waters. Not only that, but being as I have the ZHP, I find my mind wandering and wondering what combination of suspension parts I truly have? I do like to make data driving decisions. Is your coilover conversion your "final" setup for the rear? Will you be developing a coilover conversion for the front? Thanks for all you do for us suspension peeps! Kind Regards, Randy
2016 435i MSport ZHP #85
09-15-2019, 01:54 PM | #21 | |
Rep 3,540
That said, yesterday I did a good amount of dirt/gravel washboard road driving yesterday and the ride was... SMOOTH! I'm a bit underdamped right now, but I have about a 25% flat ride ratio (rear ride freq is higher than front by about 25%), and this allowed the car to settle very quickly and keep a smooth ride over lots of road texture. A few other drivers jokingly came up to me and asked if I was rattling my car apart (because even in their trucks they said they felt the dash was going to rattle apart) and were surprised when I told them it was a pretty comfortable ride, and that I heard the suspension working and doing its job more than I felt the road. The last bit for my configuration is a set of new front springs coming in (had to be shipped from Germany). Unfortunately I haven't figured out an affordable way to do the front HAS yet. If I do, you can be sure I'll do a writeup/video on it after I test the concept myself. There's one company out there that makes a front/rear HAS, but their unwillingness to provide spring rates keeps me from recommending them since you don't know what you'll be getting (and the kit's not that cheap).
09-15-2019, 02:29 PM | #22 |
Rep 509
Drives: 2016 435i
Nothing like a suspension that is working well. It has always impressed me how these Baja desert racing vehicles can ride so smooth on rough terrain at speed!
I've only seen KW that has any offerings of HAS kits lately but I do not seen anything for my RWD F32? |
