THE LARGEST BMW 2-SERIES FORUM ON THE PLANET
2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications Bimmerworld m tech front lip
      08-19-2019, 04:28 PM   #1
Arc1703
Drives: 2015 M235i 6 spd
I ordered this part and it arrived with a tube of liquid with the hardware. What is this used for? Has anyone installed this lip before?
Thanks.
      08-19-2019, 04:29 PM   #2
Arc1703
This is the tube.
      08-20-2019, 02:10 PM   #3
therza2169
Drives: 2012 Mazdaspeed 3
What's the quality seem like of the lip? Please post photos once you get it installed.
      08-20-2019, 10:33 PM   #4
HaiDef
Drives: M240i
that tube is glue. You add it on somewhere near the tape i believe for more support to stick.
      08-20-2019, 10:55 PM   #5
Arc1703
installed. Fit was perfect and installation was easy.
      11-04-2019, 02:31 PM   #6
sandrik93
Drives: '23 M240i RWD
Did you use the glue?
      11-04-2019, 11:46 PM   #7
Arc1703
I did not
      11-09-2019, 05:57 PM   #8
sandrik93
I did not
Where did you use fasteners and the screws that came with the lip?
      11-10-2019, 04:40 PM   #9
Arc1703
I did not
I just lined up the lip on the bumper and unscrewed the hardware in the bumper where the holes lined up with the lip. Then I put the adhesive on and then put screws into every hole in the lip that I could
      11-11-2019, 09:06 AM   #10
sandrik93
Gotcha. thanks. Got it installed this weekend. Didn't even need to lift the front end
      02-15-2020, 02:31 PM   #11
Hap
Hap's Avatar
153
Drives: 2018 240i
2018 M240i  [0.00]
Nice
Looks nice I may have to get that for my m235i
Is it gloss or flat finish ?
Are you still happy with it after some miles on it ?
Where did you get it ?
I am not familiar with sellers ?
I am new to this BMW thing.
Hap
      02-15-2020, 02:35 PM   #12
Arc1703
Hap
It is a matte finish. Still looks good after 5k miles. I got it from bimmerworld. It's the "m tech front lip" on multiple sites and is essentially a reproduction of the oem m performance front lip.
      02-15-2020, 02:39 PM   #13
Hap
Hap's Avatar
153
Drives: 2018 240i
2018 M240i  [0.00]
Ok
Thanks Arc....it really does look nice on your car.
Since mine is in winter storage I am looking for things to do to it
Thanks for quick response.
Hap
      08-24-2020, 02:55 PM   #14
DJR1971
Drives: 2015 M235i Estoril Blue
Name:  Bimmerworld Front Lip.jpg
What is the second part for (circle and X)? Just got my Bimmerworld splitter/lip with no instructions. Call them and they said they are not familiar enough with the part...
KennyFSU1104.00
      09-10-2020, 03:24 PM   #15
ninthvision
ninthvision's Avatar
Drives: Black M235i 6MT
Originally Posted by DJR1971 View Post
Attachment 2396887
I read on a thread that part goes into the bigger piece? If I'm not mistaken it should be a direct fit only one way
Instagram: @ninthvision
https://www.instagram.com/ninthvision/
if you're local hit me up for pictures or video
      09-12-2020, 05:59 PM   #16
PeterWT
PeterWT's Avatar
Drives: '17 M240i, AT, BSM
I've had my eye on this for a while, finally ordered it today. Looking forward to installing it.
Edit: I got an email advising the lead time for fulfilling the order is 30-60 days... :-(
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
      09-27-2020, 12:44 PM   #17
PeterWT
PeterWT's Avatar
Mine arrived today, faster than I thought it would. I'll probably install it next weekend.
For those that have already installed it, did you glue the 2 parts together before installing the lip assembly on the car? Or, did you just put them together with the attached double-stick tape and then screw it onto the car?
Trying not to overthink this, but want it to be securely mounted and stable. Last thing I want is for it to come loose at highway speed...
Arc1703 , sandrik93 , DJR1971 , thoughts? Thanks!
      09-27-2020, 02:04 PM   #18
Arc1703
I taped together the two bumper pieces and then taped that assembly to the bumper. Then I screwed the assembly in through the bottom.
PeterWT253.50
      09-28-2020, 09:20 AM   #19
sandrik93
I glued the 2 pieces together since tape didn't seem to hold em well together. But that's the only time I used the glue. For mounting I used screws and tape
PeterWT253.50
      09-29-2020, 12:01 PM   #20
ninthvision
That smaller circled piece goes inside the larger lip piece correct? Or does it attach separately?
      09-29-2020, 07:22 PM   #21
PeterWT
PeterWT's Avatar
Yes, the smaller piece goes inside the larger piece. It only fits one way. I glued them together using the supplied glue and clamps because the attached tape didn't hold well. This should have come assembled from the factory. But, I guess for ~$300 less then the BMW part, they have to cut costs somewhere... some assembly required.
      09-30-2020, 11:04 PM   #22
ninthvision
Ah I see, okay thanks! Wonder why it's 2 pieces when it could just be made as one piece if it fits directly inside it lol do you have a picture of it installed on straight on at a low angle? I saw one before where it looks like theres alot of empty space in the middle area where the 2 bolt points and the front bumper are
2addicts
