08-20-2019, 08:23 PM | #1 |
Rep 215
Front vibration - can't figure it out
Hi Folks - got a 335xi 2014 M Sport...recently I have been experiencing some front vibration as follows:
At first, I though it was a combination of wheel balancing & rotors, so I took it to the BMW dealership who told me the following:
So I went ahead and bought a new set of BMW OEM wheels w/Pirelli RFT, new Zimmerman rotors & pads....after balancing and installing, I've noticed...NOTHING has changed...the vibration is still there, which is very annoying. I went to a tire shop to check the wheels and they told me they are perfectly balanced with no bends...I also checked the old rotors & pads which were also good...so now I am pissed off, because I spend thousand of $$ to replace parts that I actually didn't need I have re-booked an appointment @ the dealership to give them a piece of my mind, but I have a feeling they will continue along this trial & error path at my expense, until the problem is solved Has anyone else experienced anything similar? Is this a symptom of bushings, rods, engine mount, drive shaft, etc?...appreciate any help or sharing of similar experience Last edited by rockblock; 08-20-2019 at 08:46 PM.. |
08-21-2019, 12:10 AM | #2 |
Rep 479
Currently going through the same problem. 46k miles. Post back if you figure yours out. Bmw gave up on looking for my problem and I have to wait until next month for the Indy to take a deeper look.
08-21-2019, 02:11 AM | #3 |
Rep 937
Going through the same thing since purchasing the car with 36k miles, now I'm at 70k.
I've road force balanced, aligned (because I lowered car), and had 2 wheels refinished because they had *minor* bends, still nothing. Just to keep a record and see if we find something in common-> 335i, 403m, PS4S.
Hi
08-21-2019, 10:51 AM | #4 |
Rep 163
are you guys all xdrive? im wondering because I had a very similar problem on my e70 LCI X5 35i and the issue ended up being that the chain in the TC had developed slack. the most notorious sign happens when on a complete stop, turning and accelerating at the same time, there would be a jerk-pulsating-vibration felt in the steering wheel and front end of the vehicle. it then would make the front end vibrate at higher speeds when coasting and off the accel pedal. im still not 100% as to why slack on the TC chain would create vibration at higher speeds, but it solved the problem for me.
2020 X3MC
