08-31-2019, 08:15 AM | #1 |
Rep 4
What about Awron display gauge? Discontinued!?
Hi guys! Do you have any news about Awron? Looking to buy one, but there are no info's, website ...anything. Should I search a used one?
09-15-2019, 03:38 PM | #2 |
Rep 2,856
Drives: BMW M2 CSL Turbomeister
Awron no longer active
Guys, just to let you know Awron is no longer active.
Displays are not for sale anymore, but if you still are looking for one make sure to reach out to Obermeier Motorsport near Munich, Germany. They told me they have a whole bunch of them on stock. Just in case you are looking for one. MR |
Spartan King79.50 |
09-19-2019, 01:19 PM | #3 | |
Rep 422
Have to install tough. What is the reason why the close their business? |
09-19-2019, 03:04 PM | #4 |
Rep 2,856
09-19-2019, 03:28 PM | #5 | |
BimmerPost Supporting Vendor
8268
Rep 18,855
I still have displays in stock for people on the US side.
09-20-2019, 08:25 AM | #6 |
Rep 2,856
12-29-2019, 02:55 PM | #9 |
Rep 2,856
Awron Gmbh who made the display is out of action. Both owners split up and the one that made the displays the last 1.5 years has stopped doing so earlier this year.
Awron Automotive is the new company and they are working on new solutions. In the mean time, AK motion's display is the only available option on the market other than stock Awron displays which are available across the globe, but there is (as far as I know) no support for those anymore. It is waiting for a new display from Awron Automotive. MR |
12-29-2019, 03:22 PM | #10 | |
Rep 422
Sounds good. |
12-30-2019, 08:41 AM | #11 |
Rep 1,263
Drives: 20 BMW M2C 17 Mazda MX-5 RF
I looked at the AWRON before deciding on the AK MOTION Center Vent Display.
Its much less expensive and I'm very pleased with it. It was $385 shipped. https://burkhart-engineering.com/epa...oducts%2F54486 It was easy to install, even though the directions were only in German. Overview over the functions of the display: (the functions depent on the motorization) automatic and manual brightness control full graphical touch-display (with 65536 colors) freely selectable bootscreen OBD2-blocker function (unlock with freely selectable code!) enable diagnostic (OBD2) by DataDisplay freely selectable color scale (e.g. oil temperature red, yellow and green) torque compesation value (e.g. for vehicles with chip tuning or powerbox) read and delete engine error code adjustable shift light (shown on the display or/and flash on the instrument cluster) save and reset max values Delete - R (F-series without cat code) torque power speed (possible to match with GPS) water temperature oil temperature gearbox temperature (automatic and DKG vehicles. E-series and F-series) battery voltage boost pressure (actual value) boost pressure (target value) Wastegate positon charge air temperature (IAT) air flow firing angle ignition time lambda value rail pressure fuel pressure exhaust temparature (calculated) oil pressure (F-series. E-series with external sensor) DPF differetnial pressure pressure before DPF soot mass DPF driven distance since successfull regeneration of DPF timing 0-100 timing 100-200 timing 1/4 Mile timing 1/2 Mile timing 1/8 Mile freely selectable speed and timing measurement laptime (displays distance and time) G-Force enable burble (F-series) activation and deactivation of Active Sound Design (F-series) Flap control activation of the speddometer needle when igintion on optimal external sensorik (oil temperature, oil pressure, exhaust temperature, ...) Dashboard with eight freely selectable values activation and deactivation of DSC/DTC while starting the vehicle (E-series) activation of relays: up to four relays can be controlled with the unit Compensation of scaled maps (for N54, boost pressure > 1,5 Bar) selecting language and units (englisch, german, italian, french, dutch, Bar-PSI, PS-KW, Lambda-AFR, °C-°F, etc…) saving of the last four timing measurements up to four freely selectable parameters which can be displayed in the flow diagram freely selectable values which can be displayed as values or as bar diagram (up to three) unit is updatable HTH, HAZMAT
2005-2006 BMWCCA Boston Chapter president
2004 Mazda Rev It Up Finalist 2002-Present HPDE Instructor My 2020M2C Build: https://f87.bimmerpost.com/forums/sh....php?t=1696726 |
12-30-2019, 09:23 AM | #12 | |
Moderator
29682
Rep 13,139
See from 05:50 onwards:
///M is art ↔ Artemis
12-30-2019, 02:00 PM | #13 | |
Rep 1,263
They shipped mine within a couple days and it arrived soon after that here on the East Coast US. All in it was less than $400 US... U could call or email them to see if its still available....
12-30-2019, 03:14 PM | #14 |
Rep 1,152
AK Motion is available here https://alpha-n.shop/produkt/ak-moti...m2-competition
01-01-2020, 10:59 AM | #15 |
Rep 2,856
01-02-2020, 12:31 PM | #17 |
Rep 2,856
03-29-2020, 01:27 PM | #18 |
Harbi GTRS3
Rep 5
Arwon Guage Softwear
i just bought and installed the arwon gauge but i need the softwear to to fix the readings and change the language.
if someone has the softwear or link that can be shared with me as arwon site is no longer active. thank uu |
03-30-2020, 03:49 AM | #19 |
Rep 422
It does not need software to change the language. You can change the language by entering the configuration page - please find a youtube video how to enter. In configuration you can also change the readings (for example PSI vs BAR, etc).
03-30-2020, 12:05 PM | #20 | |
8268
Rep 18,855
04-04-2020, 06:19 PM | #21 | |
Rep 2,856
It is a feature they installed to make sure people would come back to the dealer or headquarters to see where the display were going and to make money on the lock. You need to find an authorized dealer that can connect a laptop to the USB cable and reset your Awron display with a piece of software! MR |
11-09-2020, 11:38 AM | #22 |
Rep 5
I know this post is aging, but if someone knows the owner. Could we at least get them to release the software so it can be open sourced? Maybe even the cad models so if we wanted to build one we could? If they are out of business this shouldn't be asking too much.
Tags |
awron |
