09-22-2019, 08:59 PM | #1 |
25cent millionaire
253
Rep 1,220
Drives: 2020 m4 comp vert
octane question
hey guys I have a question on octane.. I just bought a 2017 x1msport.. now I am filling up with 3/4 of 87 octane and 1/4 94 octane, this saves me a bit of money over a full fill up of 91octane, Can anyone see any potential issues with doing this on the b48 engine?? I use Costco for 87 octane and husky for 94 gas.
09-23-2019, 06:32 PM | #2 | |
Rep 310
But, the financial savings may be negated if you need to go out of your way to one of the gas stations. Luckily I go to the same gas station that's a block away, so I dont use more gas per trip. |
09-24-2019, 05:44 AM | #3 |
Rep 383
We have Shell Nitro unleaded here. I find it does make a difference in performance being 99 Ron. I also think it slightly improves mpg and so helps offset extra cost.
Everthing goes to Entropy in this Age.
09-24-2019, 07:06 AM | #4 |
Rep 304
You can mix different octane fuels if that’s really what you want to do, but make sure you’re getting the right mix. You’d have to do a 50:50 split between 87 and 94 to get even a 90.5 average, so at your 75:25 you’re getting more like 89. That’s the minimum for the engine so technically it should be fine, but are the savings really worth it over just filling up with 91?
09-24-2019, 01:08 PM | #5 |
Rep 1,491
In my experience (Australia uses RON for octane measurement), using 95 RON (BMW's minimum) only saves money at the fuel pump; consumption is higher. So, I've standardised on 98RON for better power and economy.
BMW F22 M240i; F48 X1 25i, BMW F20 M135i
Peugeot T9 308 GTi 270 Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182. |
09-24-2019, 06:00 PM | #6 |
Rep 310
Good point, ttimbo. I see, on average, about 20 to 40 miles per tank more when using 91 (mixing octane) or 93 on the rare occasio vs 89, based on my miles to empty meter in the dash. Using the bare minimum (89 octane) or less will likely negatively affect fuel economy, engine knock prevention and performance. On the flip side, anything higher than the recommended 91 wont result in better figures.
09-27-2019, 09:58 PM | #7 |
25cent millionaire
253
Rep 1,220
hummm I will due some more long drive tests with 89 vs 91 vs 93..
