09-27-2019, 12:44 PM | #1 |
Rep 2,526
Need Photo of 12V Cigarette Lighter Plug Under Glovebox
Hey all, working on a bit of a project, and I need to find someone with the 12v lighter socket under the glovebox to send me some pictures. Mine is just an empty hole, but I know some have this connected.
I need to see where the 12V wires are connected under the panel. If someone can get a good picture of this, it would be massively helpful! Thanks! Last edited by detroitm2; 09-27-2019 at 01:07 PM.. |
09-30-2019, 09:55 AM | #3 |
Occasionally frequent poster
3007
Rep 2,745
I had no luck with this either, and yesterday I wired-up my dashcam by running the power line all the way to the trunk (where the fuse box is). A bit of a PITA, but really, working in the bowels of the dash is no fun either, so it's a wash.
It wasn't difficult to find a circuit that was only live with the ignition, although the one I got is part of the accessory bus, so it goes on when you open the door and shuts off about 10 minutes after you leave the car. It may shut off sooner if you lock it, but I didn't worry about that.
Current inventory:
F22 & G05 Cadillac CT5-V Blackwing w/3 pedals Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2) |
09-30-2019, 11:19 AM | #4 | |
Rep 2,526
I'm wiring up a lap timer and need a power source that will shutoff with the car (or shortly thereafter). Do you happen to remember where the accessory bus was, and did it stay on while the car was running? Thanks! |
10-01-2019, 06:03 AM | #5 | |
3007
Rep 2,745
I'll have to find a drawing of the fuse box for you.
Current inventory:
10-01-2019, 06:09 AM | #6 |
3007
Rep 2,745
Can't find one. Tried to draw it.
Current inventory:
10-01-2019, 05:14 PM | #7 |
Rep 1,466
The front fuse box has un-used locations for both Accessories (called Terminal 30B in BMW parlance), and for Ignition power (called Terminal 15N). You cannot assume that just because there is a fuse in the holder, that it's actually connected to anything.
If you can pick up the correct crimp, which is available with a wire on it from BMW dealers, then you can attach it to the bottom side of the front fuse holder. There is an opening under the passenger footwell that goes to the back side of the fuse box so it's easy to access too. For ground, there is a factory grounding plate on the floor of the passenger footwell. I made a Google Docs page that lists the actual fuses in use on my vehicle (2018 LCI M2 / Manual / Exec Package) here: https://docs.google.com/spreadsheets...it?usp=sharing My WMI install thread that details this approach for the WMI controller power is here: https://f87.bimmerpost.com/forums/sh....php?t=1622247
2018 ///M2 LCI, LBB, 6MT...
Current Performance Mods: CSF FMIC, ER CP, Fabspeed Cat, Aquamist WMI, GFB DV+, NGK 97506, BM3 (Stage 2 93 OTS), CDV delete, UCP, M2C/M3/M4 Strut Brace, M3/M4 Reinforcement Rings Last edited by Nezil; 10-02-2019 at 11:03 PM.. |
10-02-2019, 01:14 PM | #8 |
3007
Rep 2,745
Dang. My research showed that there is no front (passenger compartment) fuse box in the F87, that you have to go to the trunk. I wish I had known.
Current inventory:
11-01-2021, 04:43 PM | #9 | |
Rep 2,808
Did you figure it out yourself from scratch, or were you able to find some other document to use as a base? The “fuse map“ provided by BMW is useless in terms of telling you where things actually are. It only goes halfway… For example, it says that the 12 V sockets are fuses 66, 69 and 161 IIRC, but those are spread out between the front and rear fuse boxes, and unlike your document, the map doesn’t tell you which socket is which fuse! SMH... |
