87 or 91?
06-28-2005, 08:45 AM | #1 |
Rep 17
87 or 91?
Is there really a difference in performance difference between 87 octane and 91? I have been told it is all BS.
Is there any dyno results out there? Thaks for the help. |
06-28-2005, 08:59 AM | #2 |
Rep 327
Depends on the engine. In high compression ratio engines, a higher octane is required to avoid damage to the engine.
You should use what the manufacturer recommends.
1998 323is SP manual with all the goodies in ArktisSilber + 330i auto SP PP CW iDrive/Nav SatRadio Active Steering Arktis/Beige/Poplar |
06-28-2005, 09:11 AM | #3 |
Rep 279
Do a google on AKF for different octanes. In general higher octanes are slower burning with higher AKFs (anti knock factor). Don't remember all of it but different octanes also have a different mode of propagation for the combustion front.
06-28-2005, 09:18 AM | #4 |
Absolute0
169
Rep 5,078
just go for the highest octane you can get. My friends and I did a test. Differences between: 87 and 89 difference is quiet. 91 and 89 is power. 93 and 91 is power and quiet. So there IS a difference.
To procede or not to procede......
06-28-2005, 09:39 AM | #5 |
Rep 6,158
If you're buying a BMW, don't be cheap.
you'll only save 2-3 bucks a tank, and your engine could be damaged if your knock sensor goes out. Your engine will not run at its rated power as it will de-tune itself to prevent knock with the cheap gas. it is worth risking engine damage for savings of up to 150 a year???? |
06-28-2005, 09:57 AM | #7 |
Rep 1,730
always used super in my e46, once the guy gave my wife 1/2 tank of reg and the car ran like crap.
13 F10 535xi JB/B working on it
11.75 E93 M3 MR/Black Stock (wifey) 11 F10 535i AW/CB Mods Gone |
06-28-2005, 10:09 AM | #8 | |
Rep 327
06-28-2005, 10:13 AM | #9 |
Rep 279
Excellent article for the un-initiated.
http://auto.howstuffworks.com/question90.htm Some excerpts from searches for the lazy - Octane is a measure of how well a fuel resists premature combustion, or “knocking.” Gasoline with too low an octane rating converts fuel to heat rather than power, making for less efficient fuel usage and reduced engine life. The octane rating of gasoline tells you how much the fuel can be compressed before it spontaneously ignites. When gas ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine. Knocking can damage an engine, so it is not something you want to have happening. Lower-octane gas (like "regular" 87-octane gasoline) can handle the least amount of compression before igniting |
06-28-2005, 10:29 AM | #10 |
Rep 722
My old car specified "UNLEADED FUEL ONLY" so I mostly bought 87.
My BMW specifies "PREMIUM UNLEADED ONLY 91 OCTANE" or higher so that is what I buy for it. The engine is designed for premium and has a higher compression ratio than my last car. Always follow manufacturers recommendations. Will your car blow up if you don't use Premium? Probably not. But it may cause damage over time. |
06-28-2005, 11:40 AM | #11 |
Rep 513
There's a comparison at Car and Driver. The article is old (Nov 2001) but still valid.
http://www.caranddriver.com/article....&page_number=1 |
06-28-2005, 12:40 PM | #13 |
there is no spoon
245
Rep 867
My old car was barely surviving on 91 octane. The guy at the shop actually told me when I first got the turbo done, that if I was to put anything less than 91 in, I would be back in the shop with busted motor in no time. CA gas sucks, especially for turbo cars. Is there really a noticeable difference between 87 and 91? Yes. Do I want to save 4 bucks on gas? Yes. Should I do that on a $45K car? No.
06-28-2005, 01:16 PM | #14 | |
Rep 663
It seems that the octane rating method is not the same for US and European fuels. The US rating is an average of both RON and MON IIRC and the Euro is just the RON.
E90 330i delivered 6/29/2005, ZSP/ZPP/ZCW/Step, Arctic/Gray/Walnut
